Coolant leak at rear of engine
Old 04-29-2024, 09:16 PM
jeffersonracing's Avatar
jeffersonracing
jeffersonracing is offline
Default Coolant leak at rear of engine
I have a slow coolant leak and the only place I see a drip is at the rear of the engine off the plate in front of the torque converter. The only place I can think of supplying this coolant is the freeze plugs behind the flex plate. Just reaching out for any other places that may be relevant.
Old 04-30-2024, 07:33 AM
Busted Nuckles's Avatar
Busted Nuckles
Busted Nuckles is offline
Thats what it is. Mine rusted out and i pulled the transmission and put new ones in. I think there were 2 different sizes. One may be oil plug, dont mess with it. Also got the hose and flushed out the rust in the block before reinstall. Also put in a new trans seal behind the converter while i was in there.
Old 05-01-2024, 06:27 PM
jeffersonracing
Well that kind of confirms what I was thinking and last night I was on the phone with a tech friend of mine and mentioned what was going on and he was familiar with the issue and said it was common on these engines.
Old 05-01-2024, 08:32 PM
Received 3,216 Likes on 2,967 Posts
Yeah, steel freeze plugs were just such a bad idea..... Likely saved dodge a few pennies per vehicle, so, given the volume of them they made.... a fair chunk of change. Get some good brass ones, change ALL of them.
Quick Reply: Coolant leak at rear of engine
