Obd1 Connector
Mine was hanging loose from the harness off the PMC. In the manual they call in a Data Link Connector. I bought an adapter off Amazon that fits to convert it to OBD-II, but the reader I hooked up couldn't read anything but the battery voltage. Work in progress.
I'm getting a code 35 through the off/on method, trying to sort that out. Was hoping the reader would help further, but I guess while you can convert the connections, the electronics is different.
Thank you. I found the code by turning the key on-off. One thing that is weird is that there is a slight delay between the 4th and 5th blinks.
I have the 5.2 L 318 engine. It's a conversion van on a 1994 B350 body. I have some other issues as well, so I'll start a new thread.
Also, this post is what led me to try the physical adapter with my cheap OBD2 reader. As you said - it doesn't work unless the OBD2 reader is also OBD1 compatible.
https://dodgeforum.com/forum/dodge-r...-van-b250.html
