No fuel squirting in throttle body injection - 1990 B250
Does the pump run? TBI only runs at around 15 psi or so. Of course, there is no schraeder valve to making checking pressure easy... so, gotta cobble together bits and pieces to get a gauge in there. If pressure is good, beg/borrow/rent some noid lights, and see if the PCM is even pulsing the injectors. Go from there.
noid lights (which is likely short for something, but, I don't know what... they have always just been noid lights to me....) the are just led bulbs in a small housing, with the right connection for your injector harness. They flash when the PCM pulses the injector. Of course, you can't have them both plugged in at the same time..... (noid light, and injector...) so, if you are testing more than one, just do one at a time. ![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
Around here, the local big chain auto parts store will rent them to you. Don't know about Down Under..... Either that, or a specialty tool store, like Grainger, or maybe harbor freight? No idea what's available where you are.
You really need to put a gauge on the fuel line.... judging what the pressure is by how much sprays out isn't real accurate.
Low pressure can be just as bad as no pressure. Of course, if NOTHING sprays out.... you have your answer.
