Need help finding the A/C actuator vacuum hose 2002 Dodge Ram 2500
That vacuum line goes in through the firewall around the heater core inlet/outlet tubes to feed the controls for the HVAC box. It should plug into the vacuum line off the intake manifold. There should also be a check valve in there to stop the wild vents from occurring. You can patch it up by cutting out the burned portions and joining the round salvageable pieces with standard rubber vacuum hose.
