2003 ram 1500 rear break line problem
the right rear break line is a rubber to the caliper attached to a metal line to the distribution block on the axel all one piece.which is discontinued.i have to buy the short rubber line to the caliper then connect a metal line to it and over to the block but the block take a different fitting.i bought the metal line from napa and its 3/16 with a standard flare but they dont have the fitting to the block.the block says it takes a m11x1.5.is there an adapter to from the metal line to the block.thanks for any help ive went to all the auto parts stores around me
dodge brake line
we went through all of the break lines at the auto stores none of them had the right fitting.i think im going to buy the line for the left side it has the steel line on it to so i can cut the fitting off it and put on the right side line and then flare.just trying to figure out if its a double flare or bubble
