Front Washer Pump
Front Washer Pump
99 Durango SLT Front washer pump failed. No longer available part but aftermarket ones all come with a wiring plug that doesn't work. I don't want to cut into the factory harness. I've tried many different manufacturers and all of them are the same. Any ideas where to find a pump that is original or aftermarket that will plug into existing harness? Anco, Trico etc are all wrong. Any help is appreciated. They all come like this which is incorrect. Washer pump comes with two flag terminals and the plug at the other end does not fit into the factory female harness.
The factory one is like this with the factory harness plugging in to this opening that has two male connectors. Original Part #4882796
