92 d150 ac
Old 07-24-2024, 08:11 PM
Jmitchell021's Avatar
Jmitchell021
Jmitchell021 is offline
Default 92 d150 ac
Installing a aftermarket electric fan, the green wire needs to hook to the positive side on the compressor clutch switch. Would that be the blue wire or the black one?
Old 07-25-2024, 06:27 AM
Moparite's Avatar
Moparite
Moparite is offline
You need a relay to hook up to a "trigger" wire which would be the compressor wire. You can't run the fan off just the compressor wire. It should be the 87 wire after the relay.
Old 07-25-2024, 07:35 PM
Jmitchell021
yes I have a relay just want the fan to run also when the ac is on. Its setup to turn on at 170 temp, but also has the wire to run to positive side of compressor that will turn on fan
Old 07-26-2024, 06:22 AM
Moparite's Avatar
Moparite
Moparite is offline
I assume you are adding this fan it's not replacing the stock fan correct?
Old Today, 07:57 AM
Jmitchell021
Yes it’s replacing the stock clutch fan
Quick Reply: 92 d150 ac
