2003 quad cab sxt water pump
Hi been seeing a wet spot under driver side of engine last couple weeks .wasn't oil but was green water anti freeze .best idea is it's looks like coming from water pump.
so question is how difficult is it for some one with minimal auto repair knowledge to do.
ive changed breaks,starter, radiator, full front suspension and othe small problems .not sure if i can do this its the V6 3.9 2003 1008,00 miles and its the original water pump
thanks for any and all pointer
Piece of cake. Just need basic hand tools. Hardest part is getting the fan off the water pump. I just put a pipe wrench on it, whacked it with a hammer a couple times to break it loose, then it came off by hand. (leave the belt on while you do this.)
I would verfiy where the leak is coming from first though. There is a bypass hose under the a/c bracket, and I have also had the timing cover leak..... and that dropped fluid on the drivers side......
Jatr24 (Today)
