2002 dodge Dakota 3.9 v6
Old 10-09-2024 | 12:12 AM
Rmcc2002's Avatar
Rmcc2002
Default 2002 dodge Dakota 3.9 v6
Was doing some exhaust work trying to fix the exhaust leak and noticed I don’t have a donut gasket that connects my manifold to my exhaust on both sides, I put them in and turns out it’s my entire manifold so I need to replace that, but does my truck need the donut gaskets anyways?
Old 10-09-2024 | 09:56 AM
If the outlet on the manifold is shaped properly, no, you don't need the gasket. If it just has a recess to install the donut into, then yep, you need it.
Old Yesterday | 01:50 AM
Rmcc2002's Avatar
Rmcc2002
would you be able to put this into terms a kid can understand I know nothing about exhausts it has Cali emissions if that helps and when we went to put the donuts on it it had none and overtime I keep having to torque the brackets together
Old Yesterday | 08:21 AM
Can you post a pic of what they look like? Or link to one that looks the same??
Old Yesterday | 11:25 PM
magnethead's Avatar
magnethead
Exhaust Manifold should have a male bulb shape, exhaust Y-pipe should have a female cup. There's no gasket. If the exhaust manifold and the Y-pipe both have cups, then the donut (bulb part) is missing or has been cut off.
Quick Reply: 2002 dodge Dakota 3.9 v6
