Replacing heater/evaporator cores access ?
Like most, my 00 Ram 2500 has no factory horizontal dash cover anymore, just an "overlay" where the **** plastic used to be after it disintegrated many years ago.
I know SOP for this is to drop the steering wheel and the entire dash for access. Wishful thinking probably, but with no dash cover above after I remove the overlay would there be sufficient access to do this job?
If I'm still going to need to drop it all, I'm sure there a gazillion bolts/screws and no idea where they are. Any help with a link to a tutorial or layout showing where all the fasteners are would be appreciated.
There is a pretty good video on YouTube done by LMC Truck that shows the complete removal of the dash (he takes the complete dash out of the truck) and re-installs it with the new dash top - the video can be seen here -
I have to do this job of replacing the dash and everything in the HVAC box to complete the restoration of the interior of my truck now that the outdoor temperatures are cooler here. From what I've seen and experienced, it's best to remove the complete dash unit from the truck to give you full access to the HVAC box. I purchased an all-aluminum heater core from 1A Auto, as they were the only place I could find a OE style heater core that didn't have the swivel tubes that look like leaks waiting to happen. Installing this type of OE style heater core really requires removal of the dash and HVAC box to keep the frustration to a minimum. My lower dash was disintegrating, so I pulled a good used dash assembly from a donor truck and the removal was pretty quick and relatively easy.
Thanks, quite a project for complete replacement.
I like the idea of the solid tubes, but don't like the idea of removing the entire dash assembly from the truck which seems to be the requirement if using that style.
I, too am timing it with the cooler weather now. I've had no heat for years (not a huge deal in central FL), but my ac evap went out a few weeks ago (can't complain as I got 25 years out of it lol) but no ac IS a big deal. It's a work truck so I've only got a weekend to get it done, I'm sure it's not a big deal for those who have done it but I'm sure it'll take me every bit of two days.
Edit
Found this thread, looks like I need to remove the box in order to replace both anyway so may as well go with solid tubes.
Jeezus this looks like an ordeal...
https://dodgeforum.com/forum/2nd-gen...ator-core.html
Edit
Yup, that's exactly what I did. I pulled the HVAC box out of the donor truck I got the dash assembly out of. Plan to swap out the heater core, A/C evaporator and blend doors+seals, then pull the dash in my truck and replace everything with new or donor truck parts.
Edit
Edit
