No Crank No Start, also radio is locked
Hello everyone, I have a 2017 Ram 1500 Sport. 5 weeks ago it went into anti-theft mode. Red light flahing and the radio is locked, also the cluster says Push Clutch to Start, its of course an A/T. I have had it towed to 2 different dealerships and they could not fix it. What I have read the Anti-theft needs to be reset. Does any one know how to do this?
Battery changer with the driver door open and ignition on for one to two hours, Then you need the key code and a scanner that will let you do this. Or have the dealer use a Witec 2 pod to problem the pin codes. Also remove you battery cables and see if the A/t comes back. And have the dealer check for any updates on all controllers.
