AC blend door(s) - Issue with DEF/REG/FLR 2002 Ram Van 1500
Hi all...
Here is something strange. After my intake repair my AC blend door(s) will not open for register use. Only defrost and floor work - and they work well. Also hot/cold is fine too. I had a slight issue with it before my repair...sometimes and only sometimes I had to let the gas off and then the door would flip to the dash vents (registers). I check the vacuum lines and replaced a couple of others too. Again everything works right except for dash vents...
I need to dig into this, but does anyone have any ideas? Is the actuator do all three settings? I dont have my service manual handy...it is actually over two hours away...
Thanks all.
Thanks all.
