ABS and EBrake light on
Old Yesterday | 05:17 PM
Jfreak333's Avatar
Jfreak333
Smile ABS and EBrake light on
Hello guys! I need to address another issue on my 97 5.9 ram, and it has to do with the abs and ebrake light on the cluster. I did replace the abs rear wheel sensor but the lights are stil on. I have yet to look at the fuses on the inside dash. Also where is the abs module located? Thanks in advance for your help!
Old Yesterday | 08:53 PM
2 or 4 wheel ABS??
Old Yesterday | 09:18 PM
Jfreak333's Avatar
Jfreak333
its a 4x4.
Old Yesterday | 09:24 PM
AtomicDog's Avatar
AtomicDog
Even if it's a 4x4, it could still be 2 wheel ABS for the rear wheels only. You can check to see if the truck has 4 wheel ABS by checking to see if there is wiring coming from wheel sensors in the front wheel bearing area on both front sides of the truck.
Jfreak333 (Yesterday)
Old Yesterday | 09:28 PM
Jfreak333's Avatar
Jfreak333
sorry, I didn't understand the question, but I'm not sure if its 2 or 4.
Old Yesterday | 09:31 PM
Jfreak333's Avatar
Jfreak333
ok thanks, I will take a look tomorrow. Would you happen to know where the abs module is located?
Old Yesterday | 09:47 PM
If its 2 wheel abs, there isn't one, just a dump valve.
Old Yesterday | 10:00 PM
Jfreak333's Avatar
Jfreak333
I'll have to do a thorough look. Thanks!
Old Today | 12:42 AM
AtomicDog's Avatar
AtomicDog
Post
That dump valve on my truck is just off to the side of the master cylinder. It should have an electrical wire or two going to it as well. It kinda looks like a proportioning valve that is plumbed into the rear metal brake line.
