Wheels
Old Dec 2, 2024 | 06:17 PM
ElkCon's Avatar
ElkCon
Default Wheels
Hi all...
After doing the wheel bearing, I see that my wheels are actally fake plastic chrome on steel - I never knew that - and probably didnt care LOL
BUT now that I know - what 15in aluminum wheels would fit on our vans? Is there one particular one from Dodge/Chrysler that does fit? I am looking, as always do do this inexpensively...I would consider junkyard ones to if I could find them...
I think our size is 5x115? Something like that?
Anyone have any suggestions? I just put new tires on my steel wheel and I have access to tire machines, so I can just swap them myself...thanks all
Old Dec 2, 2024 | 06:38 PM
ElkCon's Avatar
ElkCon
OK i found a chart I could dump into Excel...
here is what fits:
RAMCHARGER 79-83 5X139.7 1/2-RH 77.8
RAM 1/2 TON TRUCK 2 & 4WD 94-01 5X139.7 1/2-RH 77.8
RAM VAN 85-03 5X139.7 1/2-RH 77.8
Ford 1/2 & 3/4 TON TRUCK 79-93 5X139.7 1/2-RH 77.8
Old Dec 2, 2024 | 06:42 PM
Also look at wheel width, and backspacing. Those are important as well. You can go wider, but, should try and stay very close on backspacing.
Didn't the ramchargers have aluminum slots as an option??
Old Dec 2, 2024 | 07:57 PM
Moparite's Avatar
Moparite
This may be helpful. https://www.crawlpedia.com/bolt_patterns.htm
I had a link about backspacing also but it's closed.
Old Dec 2, 2024 | 10:33 PM
jeffersonracing's Avatar
jeffersonracing
I have a set of the aluminum bullet holes wheels I would sell. They came on the 90's pickups and vans. Couple of buts, only 3 center caps and I doubt you're close enough to pick them up. Here's what they look like with the flat center caps.
Old Dec 4, 2024 | 03:04 PM
ElkCon's Avatar
ElkCon
@jeff - yea those are cool
Old Dec 30, 2024 | 04:39 PM
CAHTX01ram's Avatar
CAHTX01ram
Are those stock tire sizes? I was thinking of going 16s
Old Dec 30, 2024 | 04:55 PM
jeffersonracing
If you are referring to the picture I posted then yes those are the stock size tires and wheels.
Old Dec 30, 2024 | 05:17 PM
Los_Control's Avatar
Los_Control
Nice link, I have been wanting something like that .... thank's
Old Yesterday | 04:27 AM
zunepuh's Avatar
zunepuh
Originally Posted by ElkCon
Hi all...
BUT now that I know, what 15in aluminum Dodge Wheels would fit on our vans? Is there one particular one from Dodge/Chrysler that does fit? I am looking, as always, to do this inexpensively and I would consider junkyard ones too if I could find them.
Check your bolt pattern first as Dodge/Chrysler minivans are typically 5x127mm. Hit the junkyard and look for mid to upper trim Dodge Grand Caravans or Chrysler Town & Country vans from the mid-2000s through 2020, they all shared the same bolt pattern and came with aluminum wheels from the factory. Easy swap since you have the tire machine.
