1994 Dakota 5.2 4x4 no overdrive
Old Yesterday | 06:33 PM
Brday227's Avatar
Brday227
Default 1994 Dakota 5.2 4x4 no overdrive
I’ve had no overdrive since I’ve bought the truck. I’ve replaced trans fluid, overdrive/tcc solenoid, tps sensor, checked throttle valve cable and have been trying to find trans temp sensor but not sure if my truck came with one. Is there anything else I can try or anything I can bypass for overdrive to work. It shifts and downshifts perfect in all other gears.
Old Yesterday | 08:30 PM
Quite likely there is no trans temp sensor on yours. Is the Trans Temp lite on?? What about the O/D off switch?
Old Yesterday | 08:34 PM
Brday227's Avatar
Brday227
No there is no trans temp light on the dash and the button works.
Also the torque converter is working and locking up normally
Old Yesterday | 09:09 PM
onemore94dak's Avatar
onemore94dak
Light off = OD on
Light on = OD off.
Old Yesterday | 09:11 PM
Brday227's Avatar
Brday227
Yeah it works fine
I’ve tried unplugging it and that didn’t do anything so I plugged it back in
Old Yesterday | 10:10 PM
All it does is send a momentary signal to the PCM. The PCM turns on the little light.
What RPM is the engine turning at 55 mph?
Old Yesterday | 10:11 PM
Brday227's Avatar
Brday227
Old Yesterday | 10:12 PM
Ok, yeah. That's too high.
Does anything change when you disable O/D?
