Customer Preferred Packages
Old 08-22-2006, 06:59 PM
Jenks's Avatar
Jenks
Jenks is offline
Default Customer Preferred Packages
Can anyone tell me what these are for a 2002 1500 qc? Thanks.
2TGA Customer Preferred Package 2TG
26G Customer Preferred Package 26G
Old 08-22-2006, 08:37 PM
dodgedlr's Avatar
dodgedlr
dodgedlr is offline
Default RE: Customer Preferred Packages
26G = 5.9L Magnum/Auto, SLT,
2TG = Cant find. But it will also be a SLT, but a different engine/trans. combination.
Old 08-23-2006, 01:03 AM
eatsleepdrivesc's Avatar
eatsleepdrivesc
eatsleepdrivesc is offline
ORIGINAL: dodgedlr
2TGA=4.7 Magnum/Auto, SLT (on my Buildsheet its 2TGA)
Old 08-23-2006, 07:45 PM
Jenks's Avatar
Jenks
Jenks is offline
Thanks guys. I had sent an e-mail to dodge with my vin number and most of it made sense, but I couldn't guess what those 2 were. Thanks again.
Here's the full list that they sent me.
Sales records indicate your vehicle came equipped with the following:
V9DV Cloth 40/20/40 Bench Seat
AJKP Convenience Group
APAS Monotone Paint
A07P 5.9L Engine(EML)/4Sp Auto Trans(DGT)
BAZS 136 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BRRS 4 Wheel Disc Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CFMP Rear Folding Seat
CGDS Front Height Adjust Shoulder Belts
CGWS Next Generation Front Air Bags**
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CUES Rear Underseat Compartment Storage
CUSP Overhead Console w/Trip Computer
DGBS All 4-Speed Automatic Transmissions
DGT 4-Spd. Automatic 46RE Transmission
DHAP Lock-Up Torque Converter
DHES Man Shift-on-the-Fly Transfer Case
DJMS 205MM HD Front Axle
DMDS 3.55 Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
EAGC All Gas Engine
EML 5.9L V8 MPI Engine
GACS Tinted Glass Windows
GFD Rear Sliding Window
GNKP Rear View Auto Dim Mirror
GNMP Passenger Side Sun Visor w/Mirror
GTSP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFP Floor Tunnel Insulation
I60S Route 60 - CSX, Westboro, MA
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
K1ZP *** DESCRIPTION NOT AVAILABLE ***
LBCP Glove Box Lamp
LDAS Underhood Lamp
LMAS Halogen Headlamps
LNJ Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMP Body Color Upper Fascia
MCTS Bright Front Bumper
MDAP Front License Plate Bracket
MFDP Bright Grille
MHAS Black Windshield Moldings
MTDP SLT Badge
MURS Dodge Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Bumper Sight Shields
NAA Federal Emissions
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHMP Speed Control
PR4A Flame Red Clear Coat
QR4S Flame Red Clear Coat
RAAC All Radio Equipped Vehicles
RBK AM/FM Compact Disc Radio w/Chgr Ctrl
RCKP Infinity Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTMP P265/70R17 BSW All Season Tires
TZAP Goodyear Brand Tires
WF1S 17" Steel Spare Wheel
WF5 17X8.0 Cast Aluminum Wheels
WLZC All Aluminum Wheels
WMJP Center Hub
XBSS Pickup Box
YAAS Build To U S Market Specifications
YGCA 7 Additional Gallons of Gas
ZBSP Spring - Left Rear
ZCGP Spring - Left Front
ZPSP Spring - Right Rear
ZRFP Spring - Right Front
Z6CS GVW/Payload Rating
1AAS U.S. Dealer Retail
131S Zone 31-Boston
3VTA Customer Preferred Discount
4KZS 4X4 Tracking
5A6P Waterbase Paint
5I4S Four Wheel Drive (4WD)/(4X4)
5ZES 6 1/2 FT. Cargo Box
5ZKS Quad Cab
5ZLS 1500 GVW
594S Vehicle Order Tracking
6F8 Paint Order Code
6USS Label - U.S. Specifications
640S Rhode Island State Code
940S Rhode Island State Code
Old 02-25-2018, 09:29 AM
ViperGuns's Avatar
ViperGuns
ViperGuns is offline
Default 2TG & 26G Customer Preferred Group Packages
The 2TG designation (Trailer Tow Group/Thunder Road Group) is a quick order package/Customer Preferred Package which includes-Heavy Duty Cooling System, Heavy Duty Suspension, Auxiliary Transmission Cooler, Class IV Receiver Hitch, 7 Pin Wiring Harness, Trailer Tow 4-Pin Connector Wiring, 3.92 Rear Axle Ratio, ect...
The 26G designation is another Customer Preferred Package/Quick Order Package which includes the 5.7L Hemi V8 Engine, Next Generation Engine Controller, 5-Spd Automatic 545RFE Transmission, Lock-Up Torque Converter, Anti-Spin Rear Differential, ect...
But before anyone says "hold on now", every Make/Model by Manufacturing Build Year has these same designations and will have different Parts & Options than another Vehicle in the Chrysler/Dodge/Ram/Jeep Family. So. for the above Options with the 2TG & 26G Customer Preferred Packages, one would need to have a 2005 Dodge Ram 1500 SLT. If you had a 2004 Jeep Wrangler with the same 26G Customer Preferred Package designation it would have different options than the Ram. Anyway, that's my two cents!
File Type: pdf
Old 04-30-2024, 03:08 AM
Jimmy2Lips's Avatar
Jimmy2Lips
Jimmy2Lips is offline
Default 04 Dodge Ram 1500 RWD with same options and packages
I've got the same options on my 04 Dodge Ram 1500. I've attached a copy of my build sheet below to compare.
File Type: pdf
Quick Reply: Customer Preferred Packages
