NEW Product!! GREEN CAI now in stock!!
Hey guys we are now a Authorized Dealer for GREEN High Performance Air Filter and CAI's. This are top notch, high quality filters and CAI's. They have a few differences from the K&N stuff and are just as good in our opinion. Heres the scoop on the CAI for the Hemi Rams;
Made for the 2002 to 2005 Dodge Ram 1500 with 5.7L Hemi Engine
Green Air Power Intakes Give You: [*]Increased Horsepower[*]Increased Torque[*]Improved Throttle Response[*]Better Air Flow (Better Fuel Efficiency)
After you install your Green Air Power Intake, you will notice your vehicle's increased performance the moment you pull out. Each Green Air Intake comes factory assembled for easy and quick installation.
CONSIST OF:
Green Filter:[*]Steel mesh for strength[*]Woven cotton for filtration and maximum flow[*]Four stage rubber mold process - no rubber bleed for more surface area
High Flow Intake Tube[*]Custom molded oversized OEM quality intake tube[*]Aircraft stainless steel clamps and hard wear[*]Reinforced silicon connectors
Intake Housing[*]Fully seam welded, powder coated, laser cut steel housing[*]Pre-assembled rubber seal
Precision Production Green Filters are uniquely designed, engineered and manufactured steps above the rest. Major Green benefits include woven cotton, which is thinner and stronger than other materials with results of better airflow without sacrificing filtration. Green Filters are reinforced with steel mesh. The strength of mesh is crutial to the durability of your filter. Green also uses another cutting edge process to bond the rubber to the perimeter of the filter. Unlike many competitors that use high-pressure mold injection which seeps a considerable amount of rubber onto the filtering surface area, Green's 4-stage rubber process results in up to 25% more surface area.
Let It Breath Clean, free-flowing air is as critical to your engine's performance as the octane of your fuel. Reduce the restrictions in your intake system, and you'll increase the output of your engine. Green High Performance Air Filters are engineered to maximize air flow while trapping harmful dirt particles. The result of this race-proven technology is increased horsepower, improved throttle response, better fuel mileage, and greater torque throughout your engine's rpm range.
Increase Horsepower Dynamometer bench testing on an 1800cc 4-cylinder engine showed that a Green High Performance Air Filter provided a 6.7% increase in horsepower over the same vehicle with a stock paper filter.
Greater Air Flow In a side-by side test bench comparison, Green High Performance Air Filters allowed greater air flow through its filtering surface than paper filters.
We stock these CAI's for the Rams, 300c, Magnum and Chargers. If you have any questions please feel free to call, PM or email us.
CONSIST OF:
