CTEK MUS 4.3 instock and shipping! $79.99 w/ FREE Cig Lighter Adapter
CTEK MUS 4.3
$79.99
The MUS 4.3 (Part No. 56-864) is a charger that offers state of the art technology that was previously only found in CTEK’s professional product range. The charger can solve a broad range of battery-related problems and is the perfect charger for those with high demands. The MUS 4.3 offers features such as battery diagnosis that shows if a battery can receive and retain a charge, a special reconditioning function that restores stratified and deeply discharged batteries, unique maintenance charging, a mode for optimized charging during cold winter days and the charging of demanding AGM batteries (i.e. Optima). The unique display allows the user to follow the entire charging process.
The MUS 4.3 is a fully automatic 8-step charger that delivers selectable 0.8 A or 4.3 A to 12 V batteries from 1.2–110 Ah and is suitable for maintenance charging up to 160 Ah. The charger is splash and dust proof, designed to protect vehicle electronics and non-sparking, reverse polarity protected and short-circuit proof. It is delivered with a 5-year warranty.
More Details
Features
Fully automatic charging and maintenance in 8 steps maximizes battery life and performance
Numerous accessories simplifies using the same charger for multiple batteries
One charger for the car, motorcycle, lawn mower, snowmobile, sump pump and tractor
Water-resistant so that the solution could be taken to the problem even if it rains or snows
Patented maintenance charge for a unique combination of maximized life and performance
Recondition of deep discharged batteries
Patented desulphation that extends the battery life
No sparks, short-circuit proof and reverse-polarity protected for untroubled usage
Automatic detection of end-of-life batteries that eliminates surprises
Technical Data
Spec Data
Part No. 56-864
Charging voltage 14.4 / 14.7 / 15.8 V
Charging current Max 4.3 A
Type of charger 8 step, fully automatic charging cycle
Type of battery 12V lead-acid batteries
Battery capacity 1.2 - 110 Ah, up to 160 Ah for maintenance
More Details
Features
Technical Data
Spec Data
Part No. 56-864
