Special on AeroTurbine Mufflers
We are offering a special on AeroTurbine mufflers.
Enter promotional code AT50 during checkout.
Verocious Motorsports
www.verociousmotorsports.com
sales@verociousmotorsports.com
Sorry... Here is a direct link to the AeroTurbine page in our store
http://stores.channeladvisor.com/ver...orts/Mufflers/
Several people have contacted me and asked what exactly is an AeroTurbine muffler, well ask and you shall receive =)
http://stores.channeladvisor.com/ver...b.aspx?tabid=3
Revolutionary Design
The AeroTurbine is a packless, straight thru design, high performance muffler. The company spent over three years in Research and Design to develop a muffler that used the Principles of Thermodynamics to reduce temperatures (EGT's), increase horsepower, torque, fuel economy, and reduce engine wear and tear. With it's fully welded 304 Stainless Steel construction, the AeroTurbine is nearly indestructible and guaranteed to last as long as you own your vehicle, backed by a manufacturer's lifetime warranty. Weighing in at a mere 6 pounds, the AeroTurbine is a natural choice for the performance minded enthusiastm and is available in 2.5" through 5" inlet/outlet sizes
Learn How It Works
As the exhaust stream enters the AeroTurbine, it expands to fill the cylindrical chamber. This expansion slows the exhaust stream, creating a lower pressure at the inlet or scavenging effect, similar to that of a header. The exhaust stream is then split via an airfoil cone with an orifice similar to a conical jet engine. The outer stream accelerates to a higher velocity as it flows around the cone and has a lower pressure than the core stream, which is traveling at a slower velocity, and a higher pressure. The two streams are reintroduced via perforations in the center core. The high pressure inner stream is initially drawn out of these perforations as the gas attempts to equalize the pressure differential between the two streams. As this occurs, the change in direction of the exhaust stream causes destructive interference, which deadens the sound. As the pressure is equalized towards the rear of the canister the exhaust gas is pushed back through the helically arranged perforations in the center core, which spin the exhaust stream, causing additional sound cancellation, reducing turbulence, and creating a vortex that enables the gas to more efficiently exit the muffler.
This revolutionary design has been tested and proven to flow more exhaust gas than straight pipe. The quicker you can draw spent gases away from your engine the more power it can make.
Race Proven Performance
The AeroTurbine muffler has stormed onto the race scene with great success. From Nascar, to Rolex Series Grand Am cars, to being the official muffler the Nascar and UROC, the AeroTurbine has become the muffler of choice for those looking for the ultimate in performance.
After the Rolex Grand-Am Series tightened noise restrictions, the Chip Ganassi team requested mufflers from several leading manufacturers, including AeroTurbine. After testing all the mufflers on their race cars they announced the AeroTurbine was the muffler of choice for the team. "We are now using AeroTurbine mufflers exclusively on our Grand-Am cars. They simply outperformed all the others we tested. They are lighter, fit great in the room allotted to them, and the best thing is they make horsepower," said Jeff Lohman, assistant engineer at Chip Ganassi Racing.
AeroTurbine mufflers have also been adopted by Riley Technologies and the SunTrust Pontiac Teams, who both compete in the Rolex Grand Am Series, after testing the mufflers on their cars.
Brandon Riehl who races in the Nascar AutoZone Elite Division, and most recently Rusty Wallace are also both using the AeroTurbine. AeroTurbine has been named the official muffler of Nascar for the '06 Season
Learn How It Works
ORIGINAL: VerociousMotorsports
I just ordered an Aero Turbine, I entered the promotional code, and it said that it was not valid. I completed the order anyways. I have cheapo free flow muffler on my 06 ctd right now,,,, Im hoping everything I read is right and this one will be an improvement.
Trending Topics
ORIGINAL: usafr
Thanks,
The Verocious Motorsports Team
