Wheels & Tires Discuss rims and tires here.
Question for Ben at Tire Rack?
Old Jan 11, 2008 | 08:14 PM
03261996jc's Avatar
03261996jc
Default Question for Ben at Tire Rack?
Will I have any probs with brakes or calipers if i changeout my stock 20s for 17s on my 06 ram 1500 4x4 and what offset do you suggest?
Old Jan 15, 2008 | 01:20 PM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: Question for Ben at Tire Rack?
With normal brakes, the truck will take 17" wheels just fine. Offsets can vary. I have wheels that will fit with offsets between 10 and 35mm. Not all wheels with these offsets will fit, but that's the range I see. Lower offsets are used if you lift it (often going to the negative side). Lower offsets stick out farther, higher offsets sit in further.
