Wheels & Tires Discuss rims and tires here.
Bigger tires=Better performance?
Old Jul 13, 2006 | 11:53 PM
LoFlyer's Avatar
LoFlyer
Default Bigger tires=Better performance?
I've got a 1500 QC 4x4 with 17in rims 245/70/17. It's time for new tires and I was considering upsizing to 265/70/17 and was wondering what were the tradeoffs in that switch? Would I get better stop/start traction but worse gas mileage? Will the added size and wt change the handling characteristics?
Old Jul 14, 2006 | 08:32 PM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: Bigger tires=Better performance?
265/7017 was the optional size for some of those 1500s, so it should work fine. Bigger tires give you more traction for acceleration, braking, and turning. The increase in height can change the handling a bit. The weight difference will slightly impact the fuel mileage, although the taller tire gives slightly taller gearing, and may offset this in highway use. The bigger tires will also look better
Old Jul 23, 2006 | 01:04 AM
dacaur's Avatar
dacaur
taller tires will give less acceleration. The 265/70/17 is about and inch taller and an inch wider than a 245/70/17. So you will have a bit less power when accerlerating.
Old Jul 25, 2006 | 04:22 PM
Ben@tirerack
Dacaur, you are correct. Taller tires = taller effective gear ratios = slightly reduced acceleration
Old Jul 25, 2006 | 08:34 PM
LoFlyer's Avatar
LoFlyer
How will larger tires affect my speedo? If tires are 5% bigger does that mean my speedo will indicate 5% slower than I am actually going?
Old Jul 31, 2006 | 05:42 PM
Ben@tirerack
Correct. The % difference in overall diameter will be the % difference in speedometer and odometer readings.
