Wheels & Tires Discuss rims and tires here.
'89 Van 250Ram, 5 Bolt 15" now, want 16"
Old Aug 1, 2006 | 06:05 PM
TomBrooklyn's Avatar
TomBrooklyn
Default '89 Van 250Ram, 5 Bolt 15" now, want 16"
Hi,
Can I get a 16" wheel for a 1989 Ram250 Van and use LT245/75/16 tires? This vehicle has the 5.2L engine and 5 bolt wheel pattern.
Thanks,
Tom
Old Aug 1, 2006 | 07:27 PM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: '89 Van 250Ram, 5 Bolt 15" now, want 16"
I have listings for the 90 Ram 250, but not the 89. That shows me a 16x8 wheel with a 5x5.5 bolt pattern and 0 offset that will fit for the '90. The 245/75 is going to be taller and wider than the van came with, but would definitely mount on that 16x8 wheel. You should double check to make sure you have proper clearance before buying the tires though. To see wheels that Tire Rack has to fit your van, go to our wheel page and shop for a 90 Ram Van 250. This of course assumes that the 90 and the 89 would accept the same wheels.
