Wheels & Tires Discuss rims and tires here.
2005 SE MAX TIRE SIZE FOR A SRT-4 RIM
Old Aug 1, 2006 | 03:32 PM
flynunn's Avatar
flynunn
Default 2005 SE MAX TIRE SIZE FOR A SRT-4 RIM
NEED SOME TIRE AND WHEEL EXPERTISE, I HAVE A 2005 SE AND I RECENTLY PURCHASED A SET OF SRT-4 STOCK RIMS...WHAT IS THE LARGEST TIRE I CAN PUT ON THEM WITH OUT ANY COSTLY MODS? WILL 205/45/17 WORK???
Old Aug 1, 2006 | 06:30 PM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: 2005 SE MAX TIRE SIZE FOR A SRT-4 RIM
That is tricky, because those wheels are only 6" wide. I would normally recommend a 205/40-17 with an extra load designation, but those need a 7"wide wheel. 205/45-17 is almost an inch taller in overall diameter, so your speedometer reads a little low, odometer reads low, and there is the possibility of rubbing. Those still call for a 6.5" wide wheel. 205/50-17 is the size the SRT-4 uses, which fits the wheel correctly but is another size bigger than what is optimal for the car. I would try test fitting a 205/50 if possible. If a tire is mounted on to wide or narrow a wheel, it's performance and treadwear suffer, and there is the risk of it "popping off" the wheel, dumping all its air pressure.
Old Sep 6, 2006 | 02:22 AM
magegen's Avatar
magegen
if it is a stock neon with 15 inch wheels the 205/50/17's will not clear the strut towers, I just bought a set of srt wheels for my 05' sxt and the 205's won't clear the struts. A guy on the dodge forum is using a 205/40/17 with srt wheels on an older neon. What do you think about 205 or 215 40 17
Old Sep 6, 2006 | 11:43 AM
Ben@tirerack
the 205 or 215/40 would be better sizes, but they are not recommended to fit on the 6" wheel. The 40s need a 7" wheel and the 45s need a 6.5" wheel to mount correctly as I mentioned above. Good to hear from someone who's tried the 205/50s!
