50 series tires for stock wheels
RE: 50 series tires for stock wheels
Haha, no problem. Those wheels are 17x7 from what I can tell. It's going to be really tough to get a 50 series tire with an appropriate diameter on those wheels. A 235/55 or 235/50 will both fit on the wheel with no problem, but would be 1 or 2 inches shorter respectively and would have lower load capacities than the standard tire. So you would want to be sure that you were still meeting the Gross Axle Weight ratings for your vehicle. 255/50-18 is keeps your diameter perfect, and actually would fit the wheel, but might rub on the fenders.
http://www.tirerack.com/a.jsp?a=AJ7&...ires/index.jsp if you want to check out what's available in the different sizes.
