Wheels & Tires Discuss rims and tires here.
06 1500 4x4
Old Aug 13, 2006 | 05:40 AM
prerunner's Avatar
prerunner
Default 06 1500 4x4
i currently have 275/60/20 and 20x9 rims. I want to go with 17" rims.
I've been looking at the BFG 315/70/17's and a set of 17x10 rims. I just put a 2" leveling kit on. What do i need to look for in the rim for these tires to fit without rubbing. I still do not understand how to read the rims offset.
Old Aug 15, 2006 | 08:09 PM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: 06 1500 4x4
The lower the offset number, the farther toward the outside the wheel sits. Higher offset tucks the wheel further under the vehicle. You should be using a relatively low offset, generally 10-20mm for a 10" wide wheel on that truck. Make sure you have proper brake clearance also.
Old Aug 16, 2006 | 02:33 AM
prerunner's Avatar
prerunner
This is the wheel i ended up going with. Americas Tires Says it will work. So i'm hoping it will!!!!!!!
http://www.discounttire.com/dtcs/fin....5*5-5%252F5.5
Old Aug 21, 2006 | 03:49 PM
Ben@tirerack
That's a sharp looking wheel! Post here and let us know how it works out. Also, was that offset +25 or -25? It looked like it said -25, which might stick out a little farther than normal.
Old Aug 22, 2006 | 10:22 PM
prerunner's Avatar
prerunner
update:
those rims didn't work. The back calipers are bigger than the fronts, so the rim rubbed. You can get 17's, but make sure you specify that the back calipers are bigger!!!!!!
The tires looked sweet, but i decided to get a smaller one. They rubbed a bit on the front plastic below the bumper when turning.
I am going with the same style rim only 18x8.5. The tires i went down to 285/65/18's.
Old Aug 23, 2006 | 05:04 PM
67Coronet500's Avatar
67Coronet500
Thanks for good info
I have been thinking of getting some AT tires as well.
I was thinking of the BFGs 285/55/20.
I like the 20" rims and would hate to change them so soon.
I was wondering if there some reason that you didn't just put BFGs on your existing 20" rims?
I think that 285/55/20 and 285/65/18 are about the same size overall.
Is there some performance diff betweenn 18" and 20" rims?
Throw some pics up
Old Aug 24, 2006 | 02:02 AM
prerunner's Avatar
prerunner
Well......the BFG's for a 20" tire cost 394.00 per tire. I go thru tires to fast to be spanding that much money!!!!
Which is why i wanted 17's......the same BFG tire costs 226.00. Major difference.
I only went with the 18's because i didn't have any more money to dish out right now, and they were the same price. But now my tires are costing somewhere around 320.00. So now i really won't be saving much in the long run
Old Aug 24, 2006 | 04:07 PM
67Coronet500
Wow
Looks like prices have dropped then!
Discount Tire has 285/55/20 for $314.00 each - for a total of $1418 out the door (mount & bal, etc).
Tire rack has 285/55/20 for $310.00 each - plus shipping for a total of $1326.04 (still need mount & bal)
4Wheel Parts has a set of 4 with free shipping for $1203.96 (plus tax in CA)
Discount Tire also lists the the 285/65/18 for $234.00 each.
I recommend you print out the price and take it to the store.
not sure if this link will work
http://www.discounttire.com/dtcs/add...341&vid=009542
good luck man
I got pretty good wear (at least 60K) on my 285/75/16 on my 98 Ram so I would expect the same from new BFG tires.
Old Aug 24, 2006 | 11:42 PM
prerunner's Avatar
prerunner
Well i got em on today, and i guess it looks ok....looked alot better with the 17's and the other tires.However, i am not happy!!!! When i talked to the rep i explained i wanted at LEAST the same size, if not a bit bigger. The 285/65/18's are smaller tires than what i had b4. only by a quarter inch.....maybe i'm just being to picky!!!!
