Wheels & Tires Discuss rims and tires here.
Will they fit? Need quick help..
Old Dec 24, 2006 | 03:23 AM
ViperGTS's Avatar
ViperGTS
Default Will they fit? Need quick help..
looking at new rims on eBay and I need help to see if they fit.
My current rims are 14' x 5' with an offset of 48mm
The new ones; [/size]: F -18' x 8.5", offset 25 [/size]
R - 18x 9.5", offset 28.
An offset calculator says the following
Rear: The clearance from stut housing to the inside of the wheel will be 34mm LESS
The outside edge of the wheel will EXTEND an extra 80mm
Front: The clearance from stut housing to the inside of the wheel will be 21mm LESS
The outside edge of the wheel will EXTEND an extra 67mm
Old Dec 27, 2006 | 11:33 AM
Ben@tirerack's Avatar
Ben@tirerack
Default RE: Will they fit? Need quick help..
That does not look like it will work very well. A wider wheel with a significantly lower offset will probably stick out too far. May rub on the fenders, or even stick out outside of them. If you're doing a widebody kit they might work nicely though.
