Most Agressive Tire for a 14" Rim
My Stratus has good tires provided by Tire Rack but I am having a hell of a time finding tires that I like for my 81 4x4 LUV. Stock size is 205/75/14 Though I have 2 empty 15" rims matched up to 2 15" rims with H78-15 tires that I would like to keep.
So the real question is I would like 4 agressive tread tires that will fit on 14" rims or 2 agressive tires that will fit 15" rim and be the same size at the H78-15 tires so that my front and rear gear ratios are not mismatched.
Thanks in advance
Gareth
Thanks in advance
Gareth
Hi Rigel. U have a chevy LUV? I hade one once but 2WD. You may know but, the outsidecircumference is the major point regardless of rim size. Every tire brand has a slightly different overall size even if the numbers match. Your best bet would be a perfect matching set(tire and rims). If you can get the info from 2 different manufactuers just try 2 match the overall circumference. Hope I'm helping some. Happy trailing.
