Fuel Gauge Not Working
on
It's a faulty sending unit, which is integrated on the fuel pump assembly.
Welcome to the club!
I guess I better bust out the syphon and get to work huh?
Two options to overcome the no-fuel-gauge condition, without replacing the pump...I did that and still no-fuel-gauge: Use your trip odometer...fill 'er up and reset the trip odometer...drive until the low-fuel light comes on, note the mileage...continue driving until you can't stand the gamble any more and head for the gas station...fill 'er up, reset the trip odometer and repeat; Simply drive until the low-fuel light comes on, then pull in for gas. Neither is perfect, just have to train yourself to check for the low-fuel light and/or reset the trip odometer when you get gas...or both. I'm getting about 12.8 mpg in town driving with the truck drinking about 16 of its 22 gallons at 220 miles on the trip odometer. On the highway, mileage is about the same if I'm running 70 to 80 mph with the tach over 2K...when I drop it back down to 55 to 65 mph I manage to get almost 17 mpg out my 318/5.2L V-8 with tach at 1800 or slightly less. Not great, but I'll live with it...beats another high-dollar monthly payment for a vehicle that I can't service myself and won't do near the work that my old Dak will do.
Yeah, I've decided my light comes on with 4 gallons left in the tank... 18 gallons gone out of the 22. But I also only start using the trip meter after the light comes on, cause average gas milage in my truck greatly varies with my right foot! Sometimes the light comes on around 220 mi, sometimes 250, sometimes 275. But I'm usually safe to assume I have 30-40 miles left when the light comes on!
And true, its not good for the tank to run too low since it uses the gas to cool the pump, but I'd be going to the gas station way to often if I don't let it run low!!!
on
1 Post
My fuel gauge wasn't working, turned out the arm which has the floater on it, fell off inside the tank. I had to drop the tank and put the floater arm back on. Other option is to lift the bed off the truck to access the pump. Used a drill pump to pump the gas out before dropping the tank. (warning says not to use a drill pump with fuels, oh well). Siphon pumps work too.
One way to test the gauge is to disconnect the wiring harness off the pump. I cant remember exactly but it should either ping the gauge to the Full or Empty. I think it was Full? The pump sending unit works on a resistance style potentiometer if I remember right.
I have my writeup here http://www.dakota-durango.com/forum/...ad.php?t=73372
