DIY Fuel pump or Fuel Gauge trouble shooting (no dial-up friendly)
Old 11-20-2010, 08:36 PM
oxygen454's Avatar
oxygen454
oxygen454 is offline
Default DIY Fuel pump or Fuel Gauge trouble shooting (no dial-up friendly)
DIY Fuel pump or Fuel Gauge trouble shooting (not dial-up friendly)
I have seen a lot of fuel pump problems with our year(s) of trucks so I thought I would throw together a info page. All these pictures were taken from my 1993 Dakota Magnum V8.
Common Problems
  • Fuel gauge not reading properly…
a) sending unit damaged
b) floater stuck against tank (common cause is pump installed incorrectly facing wrong direction)
c) floater fell off pump unit in tank
d) check voltage on harness for voltage reading (varies depending on how full the tank is)
e) damage may have occurred to electronic board, tracing may have been rubbed off or have broken traces. Here is a link from the FAQ on how to replace the sender on the pump https://dodgeforum.com/forum/2216246-post9.html
**Some years/tanks (not mine) have an arrow on the top of the tank which has to match the arrow on top of the fuel pump. I cannot stress this part enough, the arrows MUST line up or you will have problems with readings. Mine was rubbing against the tank wall and eventually fell off giving me a constant reading of a quarter full tank.
  • Pump not pumping
a) Check wiring and grounds
b) Check voltage on harness at pump
c) Check ASD relay in the fuse boxes in the engine bay. See 1995 Service Manual 95AN_8W.pdf Page. 64 (more info see bottom of this post)
d) Clogged fuel filter on pump or/and clogged external filter (some years did not have a external filter) check on your frame rail near the fuel tank or mid part of frame.
Note: one way of checking to see if the sending unit/pump is toast is to put power to the pump harness directly from the battery.
Old Pump showing wiring
TRUCK WIRING
Harness to Pump
(This may vary depending on year of your 1st Gen)
Black
Black
Light Blue Yellow Stripe
Dark Blue Yellow Stripe
Green Black Stripe
PUMP WIRING
On Pump... Harness
Black
Grey
Green
Blue
Red
What they do: (wiring harness on truck side, not pump)
Color of wire/ Stripe Color
Dark Green/Black = Pump Motor Power (constant voltage)
Dark Blue/Yellow = Fuel Gauge Sending Wire
Light Blue / Black Low Fuel Lamp
Black Ground
The wires run down the inside of the frame, then outside, through the front drivers side fender well, into the engine bay, through the firewall, then tack or fuse box then tack
NEW PUMP
Wiring Diagram
Proper Fuel Pump Line-up in and out of tank (Important!)
To access the tank, there is two ways of doing this.
1. Remove the box and access tank and wiring
2. Drain and lower tank
Caution!! When you take the fuel line clips off the tank, they are plastic and are usually brittle. I would advise to get new clips before attempting hose removal. Get the proper clips as well. (a store sold me the wrong set and they came off while driving down the road causing loss of fuel)
Checking ASD Relay:
ASD relay is in the fuse boxes in the engine bay. See 1995 Service Manual 95AN_8W.pdf Page. 64
If power and ground is applied to the magnetic coil side of the relay, the other two terminals should go closed. Use a ohms meter to test open and closed. (large number means open, 0 means closed)
More info to come...
I hope this helps you guys as it has helped me... I will add to this as more info comes along.
The following 3 users liked this post by oxygen454:
Alexander Buck (08-20-2020), Frank Guerra (09-09-2020), GREASE (08-13-2020)
Old 11-21-2010, 02:08 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
I'll post this link up in the FAQ. Good job.
Old 11-21-2010, 02:17 AM
oxygen454's Avatar
oxygen454
Great thanks crazy
Old 12-18-2010, 01:53 AM
oxygen454's Avatar
oxygen454
bump (link does not work in the FAQ for some reason?)
Old 08-24-2012, 10:09 PM
oxygen454's Avatar
oxygen454
I have been offline for a while now (had a baby) I have had a lot of questions on this topic and where to find information so I thought I would bump this thread to help out.
Old 10-08-2012, 11:21 AM
mellonhead2's Avatar
mellonhead2
mellonhead2 is offline
Have a 93 Dakota I put a new fuel pump on. It gets power for a couple of seconds and then stops. Changed the relay and still nothing. Any other suggestions that I
may try?
Old 10-08-2012, 11:29 AM
Crazy4x4RT's Avatar
Crazy4x4RT
may try?
Sounds like it might be the notorious splice. Check the FAQ just a few posts above this one for a great write up.
Old 12-04-2014, 08:28 AM
sirdon113's Avatar
sirdon113
sirdon113 is offline
Default 96 dodge dakota fuel pump issue
Started out no power to pump...
Traced back to bad relay rpl relay no power tracking wire touched 1 of many and got power...pump was working ready to put it in...
Rechecked power no 12v..
relay is loosing ground if i ground it it 12v ck ok...
question is can I just run a new ground by relay box...
Old 12-04-2014, 08:31 AM
sirdon113's Avatar
sirdon113
Default Look for
Sounds like might be loosing it's ground or coil on relay bad... ..
same thing mine did.
Old 09-21-2017, 07:25 AM
Malnko79's Avatar
Malnko79
Malnko79 is offline
Ok new to this sight. Im having fuel pump issues. So heres my story. I have a 91 dakota 5.2 it shot it run and drives but the motor desperately needs repaced. So i bought a 93 dakota 5.2 that runs and drives perfect but the fram is rotted. I took the engine, tranny all the wiring harnesses inside and out. Every control modgule, every everything and put it in my 91. Everything weent great. Got it all put back together. But, the fuel pump has no power. Ive repaced fuel pump relay, asd relay, and the fuel pump. I've also cut out and repaced the splice. Good power to all 4 wires. Im not the greatest with a multi meter or on how to read schematics. Can someone please help me.
Quick Reply: DIY Fuel pump or Fuel Gauge trouble shooting (no dial-up friendly)
