1993 possible buy
The manifold needs to match the exhaust system; it's not a "Swap just the manifold" type upgrade.
Check the injectors; somewhere in there they changed the injector flow. Not a big problem; keep the ECU with the injectors and you're still good (so it uses the proper tables). I THINK they went with BIGGER ones in 1994; BICBW.
(And it's not that much bigger; it's within the auto-correct range for the ECU, but it takes out your adjustment for running changes.)
RwP
RwP
Yep.
Of course, if you move the whole exhaust system over, then the problem is solved.
Hence my comment - it's not just "swap the manifold", it's "swap the manifold and the entire exhaust system".
And I'd swap the manifolds, and either swap the exhaust or have a new exhaust system made, if it were me.
RwP
RwP
I got the larger exhaust on Rock Auto using my 94 as the search parameter, made by Walker. It is direct fit, from the Y back including CAT it was less than $400 delivered. You may need a couple extra u bolt clamps. It improved things and I never changed the 94 manifold. I wonder what it would do if I went with the 93 manifold assuming I also got a new Y pipe?
Trending Topics
The complete exhaust was a bit larger in 1993 all the way to the back; you'd have to have a reducer in there, and that reduces (also!) the benefit of the larger exhaust.
I'd look hard at the whole thing.
GOOD news - you don't have to buy it all at one time! You can store the parts and just swap them on the designated day *grins*
RwP
RwP
The '92/'93 Y mated right up to the larger '92 exhaust manifolds, and the outlet was 3 inches O.D. I used a 3" pipe from the Y to a 3 inch in/out Magnaflow Cat. The Cat dumps straight into a 3 inch in/out Hush Thrush muffler, which is then reduced down to 2 3/4", and exits through the same Walker 2 3/4" tailpipe that onemore94dak referred to.
If you look on RockAuto, there is an option for a performance exhaust system (WALKER 17443 Dynomax Super Turbo Single System), which is the larger Walker Cat-back pieces. I just checked and it's currently showing "out of stock".
