help with balljoints
i plan on replacing my upper AND lower balljoints this weekend.....
the uppers i will need to pop the rivits, i have an angle grinder, cutoff wheel, and an air chisel ---- i am set there
the lowers, i am not sure about, i have been researching and have found that i might need to press them out of the arm? is this correct? if so, how would i go about doing it?
and like i said in the other thread, our durango is 2wd, it is not part of the recall
Trending Topics
doh! i get to the parts store, and they are like well, we have everything but the lowers...... but we might be able to find them for you in the morning..... hopefully they dont cost more than what i was quoted!
next time, im getting names, the guy on the phone when i called yesterday said in stock.... and that the hub had a new spindle nut..... it doesn't
GRRRRRRR
GRRRRRRR
so THE 2WD IS WAY DIFFERENT THAN THE 4WD!!!!!!
the lower balljoint is rivited in with 4 rivits, there is no press fitting of the bj or anything, the upper has 3 rivits, i replaced both with moogs greasables
the lower took me forever to do.... the rivites are like an inch long..... the taper on my little air chisel wasn't as long,,,,, several hours later......... the tops took me liek an hour for both.....
all done, and we got an alignment......
if i ever have to do them again, it will be easy, since the replacements bolt in......
i also did reassembly with hand tools, because i didnt want to tick off the neighbors being i was using my air compressor and air hammer for liek 6 hours straight.....
