Last edit by: IB Advertising
Browse all: 4WD
- Dodge Ram 2nd Gen How to Put Truck in 4WD
Step by step instructions for the do-it-yourself repairs.
Browse all: 4WD
Can I leave my truck in Full-Time 4WD all winter?
yea close to the same as hydra said, but you got the pt and ft backwards i believe, pt gives you better traction than ft does. and also, just so you know, you do NOT have to stop and shift into neutral to go into 4hi or 4ft, you can do that at a roll at speeds under (i believe) 30, i usually just let it coast while making the switch, but the neutral pause is only necessary for 4lo (maybe save you some time next time you need it)
anyone may be able to explain which answer is best, in detail.
I had the NV242HD case and understand it entirely. Do not use 4X4 unless you need it.
I use mainly 2WD. If I start slipping in that I throw it in 4 WD PT, If I need better traction than that I throw it in 4 WD FT pulling over each time putting the drive in Neutral to pop it in the four wheel drives. If there is snow/ice really bad on the road I just slap it in 4 WD FT and go on for the day then when I am done running around paying bills or shopping I put it back into 2 WD. I think this is the same that Hydra said to do as well more less.
You my friend are miss-informed!
You have the NV242HD Transfer Case as well. The 4X4 PT is only for that PART TIME! Do not use this ever unless you HAVE to have MAXIMUM traction. The PT stands for Part Time and thus you are supposed to use it only when need, not when you just start to slip, that is what 4 FT is for.
4X4 FT is the normal 4X4 selection you should be using on slightly slippery road conditions. This is good for all conditions including switching from dry to loose surfaces.
If you use the 4 PT selection for all conditions you are winding up your Transfer Case and differentials and you will blow your case and or other drive train components. The reason is that in 4 PT the drive lines are LOCKED and if you turn, the front moves more rotations that the rear causing the wind up (Axle Bind). This is what happens to people that use the 4PT on conditions that are semi slippery or dry. Can you say EXPLODE? https://dodgeforum.com/forum/1st-gen...-exploded.html
Look at the sun visor in the driver’s side and even it will tell you how to use your Transfer Case!
our trucks have had part time 4wd 2wd and 4 lo so i went w/ my gut and was apparently wrong
NV242HD
2WD
4PT
4WD
Neutral
4LOW
NV133
2WD
4Hi
NV231
2WD
4WD
Neutral
4LOW
NV241
2WD
4WD
Neutral
4LOW
NV244 (AWD Case)
AWD
Neutral
4LOW
By definition, a Transfer Case that operates in regular 2WD and has the ability to run in 4X4 by driver switching is technically a "Part Time" transfer case. The difference between those and the NV242HD case is that it actually has an additional 4PT selection, where all other cases just the normal selections.
So yes, you are correct Sharps, but with a slight miss-understanding.
What years had the 242? My 98' Rango had one, but I gave that truck to my B.I.L. and I am looking for another Rango, since driving my aging diesel is not my preferred errand running truck, but it's all that I've got since I have to leave the burb with my wife. I'm looking for a slightly newer Rango, 5.9 ONLY.
I would like to know what years carried the 242, so I can narrow my search for a new Rango. Thanks guys!
Don't be afraid of it. Use it properly, only 4wd when weather demands. If it (or you?) has issues going in/out of 4wd, fix that, then use it properly.
Wow old thread, anyway...
98 and 99 had the 242 that had the 2wd mode. 2000 had the 242, but it didn't have 2wd, the default position for on the road was 4 hi full time.
I'm also fairly sure that there is no viscous coupler in the 242, just a center differential. I think hydra has even since mentioned that. I personally don't see what running in 4 hi ft is going to hurt; that's how all 2000 trucks with this case normally run around.
I don't really think it's even going to hurt gas mileage, I drove 250 miles from Pittsburgh to Princeton, WV with freezing and thawing roads and a mix of sleet, snow, and rain in 4hi ft and didn't even see lower gas mileage than normal.
There's not much for sale around me now, but I 'll wait and save some cash for when I find a good Rango for sale.
2000 came standard with the NV231 that had 4Lo,N,2WD, and 4HI that's what my 2k has as well. Unless your thinking about the NV244(AWD case, rare find) they all came with a 2wd option.
