Fan Clutch
#31
I actually just replaced my fan clutch 2 days ago because I never heard my old one. It was bad. Now I hear the new one for about the first 10 or 15 minutes of driving and after that it dis-engages. It is very loud though at first start-up. It will engage if I come to a light or come to a stop. Is this normal?
#32
#33
Ya, its cold here too. It engages at red lights on my way home from work when its in the 20's. Before I replaced it I didnt know it was going to be this loud. It feels like the truck has about half the power when the fan is engaged too. I watched my mileage counter last night go from 9 mpg when the fan was engaged to 16 when it dis-engaged.
#34
#36
If you don't like to hear the fan then why don't you just remove it and go to an e-fan modification instead.
It is normal to hear the clutch engage at cold start up for the first few minutes and on a new one it will loosen up after it wares in, but just siting for a few minutes at every light and being 32 F outside temp, well it sounds like yours is on the way out and needs to be replaced. Also, you can always put a louder muffler on it so you can hear the motor.....LOL
#37
#40
Yeah I know. I'm not saying that I will never use it for work but I figure if I can get a big enough E fan then it shouldn't be a huge worry. I'm still concerned with disassemby, wiring, and reassembly. If I knew someone personally that should assist me with this then I would jump right on it.
