rear end shudder.
Old 09-03-2012, 10:56 PM
stopp429's Avatar
stopp429
stopp429 is offline
Default rear end shudder.
So i have a 98 durango with the 5.2l 4x4 and i had the rear end completely rebuilt 18k ago (all new bearings, ring gear pinion etc....) it has the 3.93 LSD diff. recently after driving on the freeway for 5+ miles when i stop on the off ramp and go to take off even slowly there is a shudder in the rear of the durango it feels like driving over a cattle guards slowly. any ideas.
Old 09-03-2012, 11:05 PM
srch4me's Avatar
srch4me
srch4me is offline
Pull the diff cover of and do a inspection for wear and tear and any damage
Posted from Dodgeforum.com App for Android
Old 09-03-2012, 11:12 PM
stopp429's Avatar
stopp429
stopp429 is offline
just changed the fluid it was black and really thin so i changed it and put in the bottle of friction modifier. i will take it out in the morning and try it. i hope its not the diff because im 3 months past the warranty.
Old 09-04-2012, 11:28 PM
stopp429's Avatar
stopp429
stopp429 is offline
it quit doing the shudder when i get off the ramp. now it does it at slow speeds in parking lots. so im lost with whats going on with it.
Old 09-05-2012, 03:49 AM
Brekar's Avatar
Brekar
Brekar is offline
Have you checked your tires back there? It's just a thought but I just replaced the rear tires of my Cadillac because of a similar problem. It started with a shudder at high speed, then it started at low speeds as well. It turned out that I had a steel belt that had separated inside the right rear tire. It might be something as simple as that.
Old 09-05-2012, 09:51 AM
stopp429's Avatar
stopp429
stopp429 is offline
i hope its not the tires there a week old with only 200 miles on them. im thinking it could be a u joint or the drive shaft. i made a appointment on friday with the local mechanic because im lost with what it could be. the u joints are tight i pryed on them with a bar with the the vechile lifted up.
Old 09-05-2012, 05:43 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
if it started around the time you got the tires id take it back to the tire place and complain that it started bc you probably got a faulty tire, they should replace it free of charge
Quick Reply: rear end shudder.
