ford taurus electric fan conversion
hey my names grant and wondering if anyone here has done the ford taurus electric fan conversion as id like to upgrade my truck a little bit. i have the fan from a '94 taurus and now just need to know what all i will need to wire it into my truck. if possible id like the fan to stay off until it is needed and then switch to the slow speed and then the high speed at different temperatures but i was told not to give current to both power wires at the same time so im not sure how id wire in a switch and 2 relays to do that as i dont want the slow speed to run all the time, only when it is needed as well the high speed only when the slow isnt doing a good enough job. im installing it on a 2003 durango with the 4.7l motor if that helps. a parts list and wiring diagram would be highly appreciated.
on
I've always used either a Flex-a-Lite 180 or 183. Single speed, 3300 cfm with very low amp draw (18 amp startup).
I think when using the Taurus fan it's important to use both speeds so you can start up in low to limit that crazy amp draw on high (24 amps vs. 36 amps).
With a single speed wiring is easy and the controller is cheap from Autozone. A little more complicated for dual fans and the controller is a bit more, but not terrible.
I have a Taurus fan and use a dakota digital controller to run it. It has a temp sensor as well as toggles for the a/c to turn it on, and it does handle turning off power to the low speed before switching on the high speed. With an 03 you might be able to use the stock electric fan wiring to toggle the fan on when needed (tuners can adjust the temp it comes on at I think), then have a single pole double throw switch for manual control. I think I'd do the controller instead though.
More info:
http://www.dodgedurango.net/forums/d...much-more.html
And yes, hammer's schematic will turn off the low relay when the high comes on, you can see that the middle relay gets power with the high one, so it interrupts the ground to the low speed relay.
More info:
Those relay sizes will be fine. You ca always step up to 8 gauge wire if you want. What I'd do separate form that diagram is fuse the low and high relays separately. I use 30amps for the low and 50 for the high.
This is a simpler diagram for a single speed fan. Basically what you'll have is a second relay and trigger for the second speed, and if you want another relay to interrupt the low trigger ground when the high comes on.
Trending Topics
