Help!!!
Old 05-05-2014, 02:22 AM
AutumnRose's Avatar
AutumnRose
AutumnRose is offline
Default Help!!!
Okay, so got a 1989 dodge ram charger about a week ago and it ran fine except when cold which i assume is normal for old trucks, but about two days ago it started dieing while running and i changed out the fuel filter and cut off the catalytic converter and got better but now itll try to die and then as soon as i hit 20mph it guns it and runs fine at speeds higher than that. So what could possibly be wrong??
Old 05-05-2014, 06:38 PM
grantshultz1994's Avatar
grantshultz1994
grantshultz1994 is offline
bad injectors, weak fuel pump, crappy gas, TPS, IAC, start by tearin your throttle body apart so you can see the jets spray, start it up and whatch the spray, if its not a fine ,ist cone you have a clogged injector and theres your problem... let me know after you do that
Old 05-07-2014, 02:57 AM
cmfriend's Avatar
cmfriend
cmfriend is offline
Default Check for codes?
Turn the key on ,off ,on ,off ,on within 5 seconds.
The check engine light will flash. Count the number of flashes.
5 flashes pause 5 more is code 55. That's the end of test.
Anything else may indicate a problem.
here is a link that I think covers your vehicle.
http://ramchargercentral.com/miscellaneous/tbi-156759/
Old 05-07-2014, 11:05 AM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
I'm not a mechanic but have had the dubious pleasure of owning a lot of old vehicles. Generally when old vehicles act up I do cap rotor, plugs and wires, oil change to make sure all that is in good shape. In your case I would also run a bottle of Seafoam through the gas tank to clean the injectors or simply rebuild or replace them. Eventually if I cannot fix it I take it to a mechanic for diagnosis. After that I decide if I want to try to fix it or pay them to do it.
Old 05-07-2014, 05:46 PM
grantshultz1994
Im in college to be an auto technician and seafoam wont remove a clog big enough to clear an injector... you need to either rebuild or replace them
Old 05-08-2014, 12:21 PM
dozer556's Avatar
dozer556
dozer556 is offline
This ^. First, you should check the codes. You're probably throwing a few now, since you cut off the catalytic converter. This will at least give you someplace to start.
Old 05-13-2014, 06:54 PM
catlad58's Avatar
catlad58
catlad58 is offline
2006 Dodge Ram 4WD AUTO light constantly flashing
