No power when I put in gear!
I just bought a 91 Ramcharger 4x4 with the 5.2 and auto trans that runs and revs fine in park but when I put it in gear it doesnt want to take the gas and falls on its face. Its been sitting up for years and wouldnt run when I got it because rats have done some damage to the wiring. I have fixed the problems I have found but not sure what is causing the problem I have now. Any ideas? Thanks
It's fuel injected
Ok so I have been working on this thing for a week or so and still have the same problem. Timing is good, new tps, new map sensor, plugs and wires are not new but they arent bad, fuel filter good, I dropped the tank and checked the screen to make sure it wasnt stopped up,I have 22 lbs of fuel pressure without vacuum. It seems to be fuel problem because I can power brake it and have my brother spray a little fuel in the throttle body while its bogging and it will come alive. It will cruise down the road fine at 55, you just gotta take your time to get to 55. Not sure where to go from here!
Trending Topics
What codes did you get initially?
22lbs fuel pressure is way to much. You should have 14.5lbs. There is no vacuum on the regulator. That is a "drain" in case the regulator fails.
How did you check the timing? Did you disconnect the CTS?
Check for excessive timing chain deflection as well.
Have you checked for vacuum leaks?
You should also check for a clogged cat converter by doing a back pressure test (or remove the cat if not needed)
