Fan Controls Not Working on 2003 Dakota
Old 12-16-2011, 01:48 PM
5hundo's Avatar
5hundo
5hundo is offline
Default Fan Controls Not Working on 2003 Dakota
Hey guys, I've got another issue now. Thought I'd run it past you...
I have already replaced the resistor, after that failed. I previously had the issue where the fan would only run on max power. That has been fixed. Now, the issue is that the fan will not come on at all.
I've checked the fuses; they all look good. Could it be the switch itself? Is there a relay that is in between? Any help is appreciated...
Thanks!
Old 12-16-2011, 02:11 PM
Ts610's Avatar
Ts610
Ts610 is offline
Could be the switch or the blower motor itself. Have you checked power to the blower?
Old 12-16-2011, 02:27 PM
5hundo's Avatar
5hundo
5hundo is offline
Nope... Not yet...
I'm going to start tearing into it tonight. I just figured there might be a failing common that someone might be able to point to. For example, that resistor was an easy diagnosis. I went to the dealership and he diagnosed the fault in 10 seconds...
Old 12-16-2011, 03:35 PM
chris1996's Avatar
chris1996
chris1996 is offline
yep the resistor is easy but not when fail 2 times there is something bigger im having something similar just that only work at max but burned the second one in abouth a month
Old 12-16-2011, 04:00 PM
NorDakota's Avatar
NorDakota
NorDakota is offline
Had the same issue in a Town & Country van. Went thru 3 resistors, wires started burning off. Had to replace blower motor.
Old 12-16-2011, 04:05 PM
5hundo's Avatar
5hundo
5hundo is offline
Hmmm... Bad blower motor, eh?
I'm sure the best bet it to get one from a wrecking yard but what do they tend to cost from an auto parts store/dealership?
Old 12-16-2011, 04:32 PM
Ts610's Avatar
Ts610
Ts610 is offline
I had the same thing happen to me. I replaced the resistor and it blew again the same day. I was told after that it is a good idea when changing the resistor to change the blower. I believe I have the same issue. Blow motor needs changed also.
Old 12-16-2011, 05:28 PM
5hundo's Avatar
5hundo
5hundo is offline
Wish the guy at the dealership would have told me that when I bought the resistor...
Old 12-16-2011, 08:08 PM
Ts610's Avatar
Ts610
Ts610 is offline
I am assuming the reason the first resistor blew was due to an issue with the blower motor. If u have any luck let me know.
Old 12-18-2011, 07:55 PM
Ts610's Avatar
Ts610
Ts610 is offline
Any updates on this? My blower stopped working tonight also.
Quick Reply: Fan Controls Not Working on 2003 Dakota
