Rpm's jumping around and almost dies
Old May 7, 2012 | 09:36 PM
rwilhelms's Avatar
rwilhelms
Default Rpm's jumping around and almost dies
So the last 2weeks I've been noticing this problem. When I'm driving and lets say I'm coming up to a red light or stop sign I'lll push in the clutch and coast up to it. When the rpms drop back down to an idle with the clutch pushed in it will drop down to about 400 rpms then jump back up to about 6-700 rpms it does this about 2-3 times then stays at steady idle at 600 rpms. The truck did die on me once this way but it started right back up and had no other problems on my drive that day. Ive also noticed that sometimes my truck idles around 600 rpms and other times 900rpms I thought that was just ecu adjusting but maybe not. I'm not sure what to make of it. I'm thinking a vaccum leak somewhere or a bad sensor of some sort but I dont know where to start.
Old May 9, 2012 | 11:50 PM
Stephen61's Avatar
Stephen61
My truck kinda was doing the same thing. But my throddle body was not pulling the cable back enough so I'm just replacing the whole intake manifold but that's just me I couldent figure out the problem my self
Old May 9, 2012 | 11:54 PM
NickCornell's Avatar
NickCornell
Idol air control or throttle position sensor
Old May 10, 2012 | 12:19 AM
00DakDan's Avatar
00DakDan
Section Moderator
It wouldn't hurt to start by cleaning the throttle body. Take it off the vehicle to do it. You'll be amazed at the cr*p that builds up in the IAC passages.
Old May 10, 2012 | 08:22 AM
rwilhelms's Avatar
rwilhelms
I'm gonna take the throttle body off this weekend and clean it. And I wouldn't think that its the throttle position sensor because there's no fluctuation in rpm's while I'm driving and I would think there would be if it was that sensor but I'm probably wrong on the assumption.
Old May 10, 2012 | 01:07 PM
BlueQC's Avatar
BlueQC
I would clean the thrOttlebody and the IAC. Here is a link.
http://www.dakota-durango.com/forum/...d.php?t=105835
Old May 10, 2012 | 01:56 PM
rwilhelms's Avatar
rwilhelms
Thanks for link but to bad it wasnt for the 4.7. I went to get a haynes manual today so i have back up just in case and they had 97-99 durango/dakota books and 04-06 or something but not the years in between. I think i should be able to get through without it though. And if the iac sensor isnt to pricy im gonna replace that right away
Old May 10, 2012 | 02:00 PM
00DakDan's Avatar
00DakDan
Section Moderator
Try this link. It's sort of a mix of the 5.2 and 4.7 throttle bodies.
http://www.craigcentral.com/durango/tb.asp
It's not difficult anyways.
