Low Oil Pressure?
Old 07-25-2013, 09:51 PM
01dak3.9's Avatar
01dak3.9
01dak3.9 is offline
Default Low Oil Pressure?
I recently replaced the oil pump and oil pressure sender and the oil pressure was up a little past the half way mark. For the fast oil change I used 10-w40 Valvoline NextGen and the oil pressure has been registering low but no valve noise. s the low oil pressure because of the oil or what?
Old 07-25-2013, 10:27 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Put a mechanical oil pressure gauge on the engine and tell us exactly what your pressures are.
The dash gauges are notoriously unreliable.
The specs are: 6 (yes SIX) psi MINIMUM at idle. At 3000 rpm between 30 and 80 psi. A general rule of thumb is 10 psi per 1000 rpm.
Old 07-25-2013, 10:54 PM
01dak3.9's Avatar
01dak3.9
01dak3.9 is offline
Ok. I'll do that when I get home. I read this over at Maverick/Comet Forums.
http://mmb.maverick.to/showthread.php?t=84418
Quick Reply: Low Oil Pressure?
