5.2 swap into 99' Dakota
Old 08-19-2014, 11:16 AM
AceMcray's Avatar
AceMcray
AceMcray is offline
Default 5.2 swap into 99' Dakota
Hi everyone. I'm new to the forum, new to Dodge and new to trucks, but have much experience building/modifying cars.
My Question: What is required/what are the complications to swap a 5.2L(2000 Dodge Ram 2wd) into a 1999 Dodge Dakota 3.9L, AT, PS, No AC, No power windows or locks. I have the complete 2000 Ram as a donor vehicle so I'm hoping that makes thing easier.
Any help is appreciated, thanks!
Old 08-19-2014, 12:59 PM
magnethead's Avatar
magnethead
magnethead is offline
motor should drop straight in and you'l just need a PCM for a 99 Dak 5.2
Old 08-19-2014, 07:06 PM
sxrsil3nt's Avatar
sxrsil3nt
sxrsil3nt is offline
Simple as this!
Old 08-20-2014, 09:50 AM
AceMcray's Avatar
AceMcray
AceMcray is offline
Thanks Guys,
Seemed like a straight forward swap...bolting the engine in anyways. Just so I've asked, the 2000 ram 5.2 pcm will NOT work in the Dak?
And use engine harness from the 5.2? or keep the V6 harness and add wires for the 2 injectors?
Thanks again!
Old 08-20-2014, 10:10 AM
sxrsil3nt's Avatar
sxrsil3nt
Probably easier for you to just splice in 2 new injectors opposed to swapping the harness.
And I believe the PCM has to be from the same year Dakota with a 5.2 - not sure the technical reason why but I"m sure Magnet or Dan could answer that.
Old 08-20-2014, 10:31 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
You need the PCM for a Dakota. The PCM connections are different on the Ram.
Quick Reply: 5.2 swap into 99' Dakota
