2001 Dakota Quad Cab - Front Noise
Changed the worn tires 6 months after buying this used truck.
Over a short time a noise has developed under the front. The noise sounds like tire alignment.
I checked and found a CV axel boot busted open. Changed the complete axle, ball joints, hub assembly just because.
Noise is still there.
Sounded to me like a misaligned tire. No pull on the steering, but took to an alignment shop. They said it was a ball bearing. No alignment necessary.
Some things I've noticed. While driving down the road, if I slightly move the steering to the left, the noise goes away. Truck rides fine, no issues.
Gas mileage sucks!
Any ideas?
Gas mileage sucks!
Any ideas?
John,
I just grabbed this from the autozone site. It was the Wheel Bearing/Hub Assembly-Front
http://www.autozone.com/suspension-s...?checkfit=true
