Trouble Codes p0340 and p1684
Old 04-22-2008, 09:00 PM
03neonRT's Avatar
03neonRT
03neonRT is offline
Default RE: Trouble Codes p0340 and p1684
You don't have to change the crankshaft positioning sensor...
Old 05-05-2008, 09:55 PM
neon riders's Avatar
neon riders
neon riders is offline
the p 1684 is the oil sending unit has a short and may be need to be replaced
Old 05-06-2008, 04:22 AM
djmagic's Avatar
djmagic
djmagic is offline
neon riders, itsa battery thing, mine stopped popping up like one week ago, no work done to it at all
Old 05-07-2008, 07:16 AM
KPC's Avatar
KPC
KPC is offline
I replaced the cam shaft sensor about 2 weeks ago and the engine lighthas not come on since.I have also had no problems with the car sputtering (so far). The P1684 code has not come up again. Only that one time.
Twomore question. WhenI put the car in gear, whydoes the engine tilt up towards the rear of the compartment? Also, I was told that inorder to check the transmision fuild you should have the car in gear. Does this make a diference?
Thank you all for your help.
Old 11-14-2008, 09:29 AM
goonies's Avatar
goonies
goonies is offline
Default cheers
What I recommend is to replace the "Crankshaft sensor" as soon as possible, and further recommend that you order the sensor straight from the "car dealer" and no place else???
Quick Reply: Trouble Codes p0340 and p1684
