bucking / misfire
Old 08-11-2015, 12:59 PM
G SKI's Avatar
G SKI
G SKI is offline
Default bucking / misfire
Not sure, but wouldn't I see a misfire on the tach? Only at idle do I feel a buck or surge or misfire. Can be in drive or neutral at idle. Several months ago I had this and new wires from autozone cleared it up. I don't know, any ideas?
Old 08-15-2015, 12:54 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
Vacuum leak?
Old 08-15-2015, 02:02 AM
tflander2015's Avatar
tflander2015
tflander2015 is offline
could be bad cat converter and you ignition coil could be only running on 2 cylinders that what happened to my car is coil died and killed cat converter
Old 08-19-2015, 02:50 PM
G SKI's Avatar
G SKI
G SKI is offline
As for plugs, I always used champion in this car. How would the NGK copper V perform? Or should I just use a copper plug?
Old 08-20-2015, 11:50 AM
TejasMtnBiker's Avatar
TejasMtnBiker
TejasMtnBiker is offline
standard copper is the way to go
Old 08-21-2015, 09:32 PM
darthroush's Avatar
darthroush
Section Moderator
NGK Copper V's are still standard copper plugs. I think that's what I had bought last for mine as I tried moving away from Autolites.
Old 08-24-2015, 10:15 AM
G SKI's Avatar
G SKI
G SKI is offline
And ho2 do you like the NGK V plug? Àny smoother running, startting better?
Old 08-24-2015, 11:08 AM
phillip123hastings's Avatar
phillip123hastings
phillip123hastings is offline
Any check engine light? Those codes might point you to the right things to test in order to find out the problem.
Old 08-25-2015, 03:14 PM
darthroush's Avatar
darthroush
Section Moderator
Mine ran fine with them in, just like any other copper plug.
Old 08-26-2015, 03:15 PM
G SKI's Avatar
G SKI
G SKI is offline
That's just it. I keep checking for codes and get done, so none yet. Car runs fine other than this buck or miss at idle , in or out of gear. Now I never been sure about tranny fluids. It's the right kind / specs but reading stick is the issue. On cold engine pull stick wipe , pull again it shows full in hot range. If engine hot and check and pull stick it shows full in hot. Always been like that. I'd like to take some out on cold too lower level and recheck on hot. But don't wanna mess anything up. Anybody else have this issue?
Quick Reply: bucking / misfire
