DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
Old 01-18-2007, 07:31 PM
03neonRT 03neonRT is offline
Send a message via AIM to 03neonRT
Default The Official MegaSquirt FAQ
1. What is MegaSquirt?
MS is a full standalone fuel and spark controller. MS can completely replace your stock PCM, however you will need additional relays and wiring etc. to power all of your accessories. For this reason most people used the stock PCM to power all the accessories and sensors, while MS takes over engine control.
2. Where can I get one?
A list of all current vendors can be found here: http://www.megamanual.com/v22manual/mintro.htm#group. You can buy the MS unit prebuilt, or get an unassembled kit and do it yourself. It is not hard to assemble the MS, even if you have not had much experience with electronics. If you are patient, not afraid to learn, and willing to do a little (or a lot ) research, then you have what it takes to build and install a MegaSquirt system.
3. Ok great. Where do I start?
First things first. Read the FAQ on MSefi.com found here: http://www.megamanual.com/
Then read through the MegaManual. This contains all the details of how the MS works, assembly instructions, setup and install guidlines, tuning, wiring... it's all here: http://www.megamanual.com/v22manual/mtabcon.htm
Since most of us 2gners will be using the MSnS-E "extra" code (the only code that will run fuel and spark on Neons), the MSextra manual will also be very informative: http://www.msextra.com/manuals/MS_Ex...nual_Index.htm
4. Specifically, what do I need to run MS on my Neon?
Option A: Unassembled kit (recommend diyautotune.com)
- MS1 v3.0 pcb
- Two VB921 high current ignition coil drivers (most kits come with one VB921 included, so you may just need to get one additional transistor)
- GM IAT and CLT sensors
- Wiring harness
- Stimulator (for powering and testing your MS before hooking it up to your car)
Option B: Prebuilt unit (recommend rs-autosport.com)
- When ordering the ECU from rs-autosport specify the follow options:
Configuration: Neon/420A
Fan control output: No (assuming stock ECM still controlls radiator fan)
Firmware: Latest stable release of MSnS-E
Map sensor: Your preference
Tachometer signal output: No (assuming no additional tach signal is needed. i.e. you're not adding any other hardware that requires a tach signal).
Upgrade to MegaSquirt II: Standard MS-1 controller
You will still need:
- Wiring Harness
- Stimulator (optional)
5. Firmware
The latest version of MSnS-E firmware can be downloaded here: http://megasquirt.sf.net/extra/ by clicking "download latest". This link also cantains all the info about the features of the "Extra" code and info about the Neon Crank Decoder, as well as hardware modifications required to control the coilpack. (the site says for pre-NGC Neons only, but MS will work on NGC cars and read the NGC crank trigger wheel)
The NGC code can be downloaded here:
http://megasquirt.texasneons.org/029v_ngc3.zip
FAQ Created by "turbodudey"
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
- 2003 R/T: COMP 400 Cam, MSD Wires, K&N CAI, Eibach Prokit, Tokico Blues, Hotchkis Tuning Sway Bars, Vibrant F/R Strut Bars, Unorthodox UDP, Maddog 72% STS, JonnyMopar Solid Shifter/Booger Bushings, Prothane MM's, Exel Speeds, Toyo PX4's, RB1 GPS System
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-01-2007, 10:57 PM
Kapitald's Avatar
Kapitald Kapitald is offline
Vehicle: 2004 E.Blue Neon Srt-4
Send a message via AIM to Kapitald
Default RE: MegaSquirt FAQ
Whats average install time on megasquirt....DIY???
__________________
04 Electric Blue Srt-4..CAI..8.5mm crane wires..front and rear strut bars..motor mount inserts..agp wastegate..manual in cabin boost controller..maddog 72% sts..greddy occ..bigger intercooler with hardpipes..hks sequential bov..possibly stage1 cam
Old 02-08-2007, 12:35 AM
Quote:
ORIGINAL: Kapitald
It all depends on your skill level with electronics and wiring really...the entire install could easily be done in a day at a steady pace. The actual assembly of the MS unit will also depend on how skilled you are with electronics.
__________________
Old 02-23-2007, 09:18 AM
blazingdisciple blazingdisciple is offline
I'm guessing the best way to start is by buying a fully assembled unit from...
http://www.rs-autosport.net/catalog/index.php
I myself would need help from someone to even install that [>:]
__________________
2003 Neon SE AXT- Only have AEM CAI at the moment, will be turbo'd someday!!
Old 03-01-2007, 02:02 AM
moparx12 moparx12 is offline
03neonRT,
i read on the megasquirt website that you can run up to 20 lbs of boost... on the regular megasquirt 1. and that you can only run the spark code with ms1 not ms2... does that mean that i couldnt run 25 lbs of boost in my car with the ms1?
__________________
thats key
Old 03-02-2007, 03:09 AM
spikeymikey87 spikeymikey87 is offline
Send a message via AIM to spikeymikey87
if you get the 4 bar map sensor you can run over 50 ( i believe 58) or maybe im making that up but deff more than 20 and yes get teh ms1 ms2 sucks balls because its a pain to work with neons
__________________
Megasquirtin all over your face
Old 03-04-2007, 04:44 PM
Quote:
ORIGINAL: spikeymikey87
You would be correct good sir...on both accounts. MS2 = Gay...at least for the moment .
__________________
Old 03-06-2007, 06:23 PM
Default RE: The Official MegaSquirt FAQ
okay, is this all im going to need to get going on this megasquirt project? besides obviously the solder materials...
1x
MegaSquirt Stimulator v2.2 - UnAssembled Kit
1x
12' MegaSquirt Wiring Harness (MS1 / MS2 Ready)
1x
GM Open Element IAT Sensor with Pigtail
1x
GM Closed Element CLT / IAT Sensor with Pigtail
1x
VB921 Ignition Coil Driver
1x
MegaSquirt-I Programmable EFI System PCB3.0 - UnAssembled Kit
1x
MegaSquirt Tuning Cable (DB9 Straight Thru)
also, my engine is not boosted right now, but it will be in the future... would it be okay to use the open element sensor in the intake of my NA engine right now so that i dont have to buy an extra sensor when the turbo is ready?
also, the stim is v2.2, and im using the v3.0 pcb, do these conflict or what?
__________________
thats key
Old 03-06-2007, 11:02 PM
I dont think it matters what MegaStim version your using, and the only thing I see missing for the actual MS unit is you'll need a second VB921 Ignition Coil Driver. As for the intake sensor, you should be fine with the open element, but I'm not 100% sure...
__________________
Old 03-07-2007, 01:12 PM
i believe the pcb3.0 kit comes with one already like you said in the first post of this thread... so i just added one more to the cart thinking that one already came with the kit.
__________________
thats key
Tags
1995, coilpack, crank, dakota, dodge, face, fan, harness, megasquirt, neon, ngc, project, radiator, signal, srt, srt4, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
