Diagnostic Trouble Code List
Old 03-10-2009, 08:28 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
Default Diagnostic Trouble Code List
This is the most extensive list of DTCs I could find, and should decode the p#### codes for most users. To read the codes on your vehicle, you will need a code reader or tuner that has a code reading funciton, such as a Superchips. Some vehicles support the key trick, and will display the codes on your odometer, some do not.
The Key Trick:
1. With the engine off, turn the key to "RUN"
2. Turn key to "OFF"
3. Turn key to "RUN"
4. Turn key to "OFF"
5. Turn key to "RUN"
6. Look at the odometer, any codes should display or if no codes display it will read "done."
Disclaimer: I do not guarantee that this list is 100% complete or 100% accurate. Myself, nor Dodge Forum are responsible for any typos, this list is for reference purposes, use the information at your own risk.
P0000 - P0099 https://dodgeforum.com/forum/1582296-post2.html
P0100 - P0199 https://dodgeforum.com/forum/1582302-post3.html
P0200 - P0299 https://dodgeforum.com/forum/1582310-post4.html
P0300 - P0399 https://dodgeforum.com/forum/1582315-post5.html
P0400 - P0499 https://dodgeforum.com/forum/1582321-post6.html
P0500 - P0599 https://dodgeforum.com/forum/1582326-post7.html
P0600 - P0699 https://dodgeforum.com/forum/1582337-post8.html
P0700 - P0799 https://dodgeforum.com/forum/1582341-post9.html
P0800 - P0899 https://dodgeforum.com/forum/1582348-post10.html
P0900 - P0999 https://dodgeforum.com/forum/1582353-post11.html
P0A00 - P0A99 https://dodgeforum.com/forum/1582358-post12.html
P1000 - P1099 https://dodgeforum.com/forum/1582363-post13.html
P1100 - P1199 https://dodgeforum.com/forum/1582365-post14.html
P1200 - P1299 https://dodgeforum.com/forum/1582367-post15.html
P1300 - P1399 https://dodgeforum.com/forum/1582370-post16.html
P1400 - P1499 https://dodgeforum.com/forum/1582371-post17.html
P1500 - P1599 https://dodgeforum.com/forum/1582376-post18.html
P1600 - P1699 https://dodgeforum.com/forum/1582378-post19.html
P1700 - P1899 https://dodgeforum.com/forum/1582380-post20.html
P2000 - P2099 https://dodgeforum.com/forum/1582383-post21.html
P2100 - P2199 https://dodgeforum.com/forum/1582389-post22.html
P2200 - P2299 https://dodgeforum.com/forum/1582398-post23.html
P2300 - P2399 https://dodgeforum.com/forum/1582400-post24.html
P2400 - P2499 https://dodgeforum.com/forum/1582409-post25.html
P2500 - P2599 https://dodgeforum.com/forum/1582413-post26.html
P2600 - P2699 https://dodgeforum.com/forum/1582417-post27.html
P2700 - P2799 https://dodgeforum.com/forum/1582431-post28.html
P2A00 - P2A99 https://dodgeforum.com/forum/1582434-post29.html
P3400 - P3499 https://dodgeforum.com/forum/1582436-post30.html
Old 03-10-2009, 08:31 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
P0000 - P0099
P0001 Fuel Volume Regulator Ctrl Circ/Open
P0002 Fuel Volume Regulator Ctrl Circ Range/Perf
P0003 Fuel Volume Regulator Ctrl Circ Low
P0004 Fuel Volume Regulator Ctrl Circ Hi
P0005 Fuel Shutoff Valve A Ctrl Circ/Open
P0006 Fuel Shutoff Valve A Ctrl Circ Low
P0007 Fuel Shutoff Valve A Ctrl Circ Hi
P0008 Engine Pos Sys Perf Bank1
P0009 Engine Pos Sys Perf Bank2
P0010 A Camshaft Pos Actuator Circ Bank1
P0011 A Camshaft Pos-Timing Over-Advanced or Sys Perf Bank1
P0012 A Camshaft Pos-Timing Over-Retarded Bank1
P0013 B Camshaft Pos-Actuator Circ Bank1
P0014 B Camshaft Pos-Timing Over-Advanced or Sys Perf Bank1
P0015 B Camshaft Pos-Timing Over-Retarded Bank1
P0016 Crank/Camshaft Mis-align/sync
P0017 Crank Pos-Camshaft Pos Correlation Bank1 Sens B
P0018 Crank Pos-Camshaft Pos Correlation Bank2 Sens A
P0019 Crank Pos-Camshaft Pos Correlation Bank2 Sens B
P0020 A Camshaft Pos Actuator Circ Bank2
P0021 A Camshaft Pos-Timing Over-Advanced or Sys Perf Bank2
P0022 A Camshaft Pos-Timing Over-Retarded Bank2
P0023 B Camshaft Pos-Actuator Circ Bank2
P0024 B Camshaft Pos-Timing Over-Advanced or Sys Perf Bank2
P0025 B Camshaft Pos-Timing Over-Retarded Bank2
P0026 Intake Valve Ctrl Solenoid Circ Range/Perf Bank1
P0027 Exhaust Valve Ctrl Solenoid Circ Range/Perf Bank1
P0028 Intake Valve Ctrl Solenoid Circ Range/Perf Bank2
P0029 Exhaust Valve Ctrl Solenoid Circ Range/Perf Bank2
P0030 1/1 02 Sens Heater Relay Malfunction
P0031 HO2S Heater Ctrl Circ Low Bank1 Sens1
P0032 HO2S Heater Ctrl Circ Hi Bank1 Sens1
P0033 Turbo Charger Bypass Valve Ctrl Circ
P0034 Turbo Charger Bypass Valve Ctrl Circ Low
P0035 Turbo Charger Bypass Valve Ctrl Circ Hi
P0036 1/2 02 Sens Heater Relay Malfunction
P0037 HO2S Heater Ctrl Circ Low Bank1 Sens2
P0038 HO2S Heater Ctrl Circ Hi Bank1 Sens2
P0039 T/Super Charger Bypass Valve Ctrl Circ Range/Perf
P0040 O2 Sens Signals Swapped Bank1 Sens1/ Bank2 Sens1
P0041 O2 Sens Signals Swapped Bank1 Sens2/ Bank2 Sens2
P0042 HO2S Heater Ctrl Circ Bank1 Sens3
P0043 HO2S Heater Ctrl Circ Low Bank1 Sens3
P0044 HO2S Heater Ctrl Circ Hi Bank1 Sens3
P0045 T/Super Charger Boost Ctrl Solenoid Circ/Open
P0046 T/Super Charger Boost Ctrl Solenoid Circ Range/Perf
P0047 T/Super Charger Boost Ctrl Solenoid Circ Low
P0048 T/Super Charger Boost Ctrl Solenoid Circ Hi
P0049 T/Super Charger Turbine Overspeed
P0050 HO2S Heater Ctrl Circ Bank2 Sens1
P0051 HO2S Heater Ctrl Circ Low Bank2 Sens1
P0052 HO2S Heater Ctrl Circ Hi Bank2 Sens1
P0053 HO2S Heater Resistance Bank1 Sens1
P0054 HO2S Heater Resistance Bank1 Sens2
P0055 HO2S Heater Resistance Bank1 Sens3
P0056 HO2S Heater Ctrl Circ Bank2 Sens2
P0057 HO2S Heater Ctrl Circ Low Bank2 Sens2
P0058 HO2S Heater Ctrl Circ Hi Bank2 Sens2
P0059 HO2S Heater Resistance Bank2 Sens1
P0060 HO2S Heater Resistance Bank2 Sens2
P0061 HO2S Heater Resistance Bank2 Sens3
P0062 HO2S Heater Ctrl Circ Bank2 Sens3
P0063 HO2S Heater Ctrl Circ Low Bank2 Sens3
P0064 HO2S Heater Ctrl Circ Hi Bank2 Sens3
P0065 Air Assisted Injector Ctrl Range/Perf
P0066 Air Assisted Injector Ctrl Circ or Circ Low
P0067 Air Assisted Injector Ctrl Circ Hi
P0068 MAP/MAF-Throttle Pos Correlation
P0069 MAP-Barometric Press Correlation
P0070 Ambient Air Temp Sens Circ
P0071 Ambient Temp Sens Perf
P0072 Ambient Temp Sens Low
P0073 Ambient Temp Sens Hi
P0074 Ambient Air Temp Sens Circ Interm
P0075 Intake Valve Ctrl Solenoid Circ Bank1
P0076 Intake Valve Ctrl Solenoid Circ Low Bank1
P0077 Intake Valve Ctrl Solenoid Circ Hi Bank1
P0078 Exhaust Valve Ctrl Solenoid Circ Bank1
P0079 Exhaust Valve Ctrl Solenoid Circ Low Bank1
P0080 Exhaust Valve Ctrl Solenoid Circ Hi Bank1
P0081 Intake Valve Ctrl Solenoid Circ Bank2
P0082 Intake Valve Ctrl Solenoid Circ Low Bank2
P0083 Intake Valve Ctrl Solenoid Circ Hi Bank2
P0084 Exhaust Valve Ctrl Solenoid Circ Bank2
P0085 Exhaust Valve Ctrl Solenoid Circ Low Bank2
P0086 Exhaust Valve Ctrl Solenoid Circ Hi Bank2
P0087 Fuel Rail/Sys Press-Too Low
P0088 Fuel Rail Press Hi
P0089 Fuel Press Regulator 1 Perf
P0090 Fuel Press Regulator 1 Ctrl Circ
P0091 Fuel Press Regulator 1 Ctrl Circ Low
P0092 Fuel Press Regulator 1 Ctrl Circ Hi
P0093 Fuel Sys Leak Detected-Large Leak
P0094 Fuel Sys Leak Detected-Small Leak
P0095 Intake Air Temp Sens2 Circ
P0096 Intake Air Temp Sens2 Circ Range/Perf
P0097 Intake Air Temp Sens2 Circ Low
P0098 Intake Air Temp Sens2 Circ Hi
P0099 Intake Air Temp Sens2 Circ Interm/Erratic
Old 03-10-2009, 08:33 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
P0100 - P0199
P0100 Mass or Volume Air Flow Circ
P0101 MAF Sens Perf
P0102 MAF Sens Low frequency
P0103 MAF Sens Hi frequency
P0104 Mass or Volume Air Flow Circ Interm
P0105 MAP/Barometric Press Circ
P0106 Barometric Press Out of Range
P0107 Map Sens Voltage Too Low
P0108 Map Sens Voltage Too Hi
P0109 MAP/Barometric Press Circ Interm
P0110 Intake Air Temp Sens1 Circ
P0111 Intake Air Temp Sens Perf
P0112 Intake Air Temp Sens Voltage Low
P0113 Intake Air Temp Sens Voltage Hi
P0114 Intake Air Temp Sens1 Circ Interm
P0115 Engine Coolant Temp Circ
P0116 Coolant Temp Sens Perf
P0117 ECT Sens Voltage Too Low
P0118 ECT Sens Voltage Too Hi
P0119 Engine Coolant Temp Circ Interm
P0120 Throttle/Pedal Pos Sens/Switch A Circ
P0121 TPS Voltage Does Not Agree with MAP
P0122 Throttle Pos Sens Voltage Low
P0123 Throttle Pos Sens Voltage Hi
P0124 Throttle/Pedal Pos Sens/Switch A Circ Interm
P0125 Closed Loop Temp Not Reached
P0126 Insufficient ECT for Stable Operation
P0127 Intake Air Temp Too Hi
P0128 Cooling Sys Error / Thermostat Perf
P0129 Barometric Press Too Low
P0130 1/1 02 Sens Heater Relay Malfunction
P0131 1/1 02 Sens Shorted To Ground
P0132 1/1 O2S Shorted To Voltage
P0133 1/1 O2S Slow Response
P0134 1/1 O2S Stays At Center
P0135 1/1 O2S Heater Failure
P0136 1/2 02 Sens Heater Relay Malfunction
P0137 1/2 O2S Shorted To Ground
P0138 1/2 O2S Shorted To Voltage
P0139 1/2 O2S Slow Response
P0140 1/2 O2S Stays At Center
P0141 1/2 02 Sens Relay
P0142 O2 Sens Circ Bank1 Sens3
P0143 1/3 O2S Shorted To Ground
P0144 1/3 O2S Shorted To Voltage
P0145 1/3 O2S Slow Response
P0146 1/3 O2S Stays At Center
P0147 1/3 02 Sens Heater Failure
P0148 Fuel Delivery Error
P0149 Fuel Timing Error
P0150 O2 Sens Circ Bank2 Sens1
P0151 2/1 02 Sens Shorted To Ground
P0152 2/1 02 Sens Shorted To Voltage
P0153 2/1 02 Sens Slow Response
P0154 2/1 02 Sens Stays at Center
P0155 2/1 02 Sens Heater Failure
P0156 O2 Sens Circ Bank2 Sens2
P0157 2/2 02 Sens Shorted To Ground
P0158 2/2 02 Sens Shorted To Voltage
P0159 2/2 02 Sens Slow Response
P0160 2/2 02 Sens Stays at Center
P0161 2/2 02 Sens Heater Failure
P0162 O2 Sens Circ Bank2 Sens3
P0163 O2 Sens Circ Low Voltage Bank2 Sens3
P0164 O2 Sens Circ Hi Voltage Bank2 Sens3
P0165 Starter Relay Ctrl Circ
P0166 O2 Sens Circ No Activity Detected Bank2 Sens3
P0167 O2 Sens Heater Circ Bank2 Sens3
P0168 Decreased Engine Perf Due to Hi Inj Pump Fuel Temp
P0169 Water-in-fuel detected for too long
P0170 Fuel Trim Bank1
P0171 1/1 Fuel Sys Lean
P0172 1/1 Fuel Sys Rich
P0173 Fuel Trim Bank2
P0174 2/1 Fuel Sys Lean
P0175 2/1 Fuel Sys Rich
P0176 Loss of Flex Fuel Calibration Signal
P0177 Water In Fuel
P0178 Flex Fuel Sens Volts Too Low
P0178 Water in Fuel Sens Volts Too Low or
P0179 Flex Fuel Sens Volts Too Hi
P0180 CNG Temp Sens Voltage Fail
P0181 Fuel Inj Pump Failure
P0182 CNG Temp Sens Voltage Too Low
P0183 CNG Temp Sens Voltage Too Hi
P0184 Fuel Temp Sens A Circ Interm
P0185 Fuel Temp Sens B Circ
P0186 Fuel Temp Sens B Circ Range/Perf
P0187 Fuel Temp Sens B Circ Low
P0188 Fuel Temp Sens B Circ Hi
P0189 Fuel Temp Sens B Circ Interm
P0190 Fuel Rail Press Sens Circ
P0191 Fuel Rail Press Sens Circ Range/Perf
P0192 Fuel Rail Press Sens Low
P0193 Fuel Rail Press Sens Hi
P0194 Fuel Rail Press Sens Circ Interm
P0195 Engine Oil Temp Sens
P0196 Engine Oil Temp Sens Range/Perf
P0197 Engine Oil Temp Sens Low
P0198 Engine Oil Temp Sens Hi
P0199 Engine Oil Temp Sens Interm
Old 03-10-2009, 08:36 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
P0200 - P0299
P0200 Injector Circ/Open
P0201 Injector #1 Ctrl Circ
P0202 Injector #2 Ctrl Circ
P0203 Injector #3 Ctrl Circ
P0204 Injector #4 Ctrl Circ
P0205 Injector #5 Ctrl Circ
P0206 Injector #6 Ctrl Circ
P0207 Injector #7 Ctrl Circ
P0208 Injector #8 Ctrl Circ
P0209 Injector #9 Ctrl Circ
P0210 Injector #10 Ctrl Circ
P0211 Injector Circ/Open-Cylinder 11
P0212 Injector Circ/Open-Cylinder 12
P0213 Cold Start Injector 1
P0214 Cold Start Injector 2
P0215 Fuel Inj Pump Ctrl Circ
P0216 Fuel Inj Pump Timing Failure
P0217 Decreased Eng Perf due to Eng Overheat Condition
P0218 Trans Fluid Over Temp Condition
P0219 CKP Sens Overspeed Condition
P0220 APP Sens2 Circ
P0221 APP Sens2 Circ Perf
P0222 Idle Validation Signals Both Low
P0222 APP Sens2 Circ Low Voltage or
P0223 Idle Validation Signals Both Hi (Above 5Vs)
P0223 Inj Pulse Width Error (Rise Time Long) or
P0224 Throttle/Pedal Pos Sens/Switch B Circ Interm
P0225 APP Sens3 Circ
P0226 APP Sens3 Circ Perf
P0227 APP Sens2 Circ Low Voltage
P0228 APP Sens2 Circ Hi Voltage
P0229 Throttle/Pedal Pos Sens/Switch C Circ Interm
P0230 Transfer Pump (Lift Pump) Circ Out Of Range
P0231 Fuel Pump Feedback Circ Low Voltage
P0232 Fuel Shut-Off Signal Voltage Too Hi
P0233 Fuel Pump Sec Circ Interm
P0234 Turbo Boost Limit Exceeded
P0235 T/Super Charger Boost Sens A Circ
P0236 MAP Sens Too Hi Too Long
P0237 MAP Sens Voltage Too Low
P0238 MAP Sens Voltage Too Hi
P0239 T/Super Charger Boost Sens B Circ
P0240 T/Super Charger Boost Sens B Circ Range/Perf
P0241 T/Super Charger Boost Sens B Circ Low
P0242 T/Super Charger Boost Sens B Circ Hi
P0243 Open or shorted condition detected in the turbocharger Wastegate solenoid Ctrl
P0244 T/Super Charger Wastegate Solenoid A Range/Perf
P0245 T/Super Charger Wastegate Solenoid A Low
P0246 T/Super Charger Wastegate Solenoid A Hi
P0247 T/Super Charger Wastegate Solenoid B
P0248 T/Super Charger Wastegate Solenoid B Range/Perf
P0249 T/Super Charger Wastegate Solenoid B Low
P0250 T/Super Charger Wastegate Solenoid B Hi
P0251 Fuel Inj Pump Fuel valve Feedback Circ
P0252 Fuel Inj Pump Fuel Valve Stuck
P0253 Fuel Inj Pump Fuel Valve Open Circ
P0254 Fuel Inj Pump Fuel Valve Current Too Hi
P0255 Inj Pump Fuel Metering Ctrl A Interm (Cam/Rotor/Injector)
P0256 Inj Pump Fuel Metering Ctrl B (Cam/Rotor/Injector)
P0257 Inj Pump Fuel Metering Ctrl B Range/Perf (Cam/Rotor/Injector)
P0258 Inj Pump Fuel Metering Ctrl B Low (Cam/Rotor/Injector)
P0259 Inj Pump Fuel Metering Ctrl B Hi (Cam/Rotor/Injector)
P0260 Inj Pump Fuel Metering Ctrl B Interm (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circ Low
P0262 Cylinder 1 Injector Circ Hi
P0263 Cylinder 1 Balance Sys
P0264 Cylinder 2 Injector Circ Low
P0265 Cylinder 2 Injector Circ Hi
P0266 Cylinder 2 Balance Sys
P0267 Cylinder 3 Injector Circ Low
P0268 Cylinder 3 Injector Circ Hi
P0269 Cylinder 3 Balance Sys
P0270 Cylinder 4 Injector Circ Low
P0271 Cylinder 4 Injector Circ Hi
P0272 Cylinder 4 Balance Sys
P0273 Cylinder 5 Injector Circ Low
P0274 Cylinder 5 Injector Circ Hi
P0275 Cylinder 5 Balance Sys
P0276 Cylinder 6 Injector Circ Low
P0277 Cylinder 6 Injector Circ Hi
P0278 Cylinder 6 Balance Sys
P0279 Cylinder 7 Injector Circ Low
P0280 Cylinder 7 Injector Circ Hi
P0281 Cylinder 7 Balance Sys
P0282 Cylinder 8 Injector Circ Low
P0283 Cylinder 8 Injector Circ Hi
P0284 Cylinder 8 Balance Sys
P0285 Cylinder 9 Injector Circ Low
P0286 Cylinder 9 Injector Circ Hi
P0287 Cylinder 9 Contribution/Balance
P0288 Cylinder 10 Injector Circ Low
P0289 Cylinder 10 Injector Circ Hi
P0290 Cylinder 10 Contribution/Balance
P0291 Cylinder 11 Injector Circ Low
P0292 Cylinder 11 Injector Circ Hi
P0293 Cylinder 11 Contribution/Balance
P0294 Cylinder 12 Injector Circ Low
P0295 Cylinder 12 Injector Circ Hi
P0296 Cylinder 12 Contribution/Balance
P0297 Vehicle Overspeed Condition
P0298 Engine Oil Over Temp
P0299 T/Super Charger Underboost
Old 03-10-2009, 08:39 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
P0300 - P0399
P0300 Multiple Cylinder Misfire
P0301 Cylinder #1 Misfire
P0302 Cylinder #2 Misfire
P0303 Cylinder #3 Misfire
P0304 Cylinder #4 Misfire
P0305 Cylinder #5 Misfire
P0306 Cylinder #6 Misfire
P0307 Cylinder #7 Misfire
P0308 Cylinder #8 Misfire
P0309 Cylinder #9 Misfire
P0310 Cylinder #10 Misfire
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected with Low Fuel
P0314 Single Cylinder Misfire (Cylinder not Specified)
P0315 Crank Pos Sys Variation Not Learned
P0316 Engine Misfire Detected on Startup (First 1000 Revs)
P0317 Rough Road Hardware Not Present
P0318 Rough Road Sens A Signal Circ
P0319 Rough Road Sens B
P0320 No Crank Ref Signal at PCM
P0321 Ignition/Distributor Engine Speed Input Circ Range/Perf
P0322 Ignition/Distributor Engine Speed Input Circ No Signal
P0323 Ignition/Distributor Engine Speed Input Circ Interm
P0324 Knock Ctrl Sys Error
P0325 Knock Sens #1 Circ
P0326 Knock Sens1 Circ Range/Perf Bank1 or Single Sens
P0327 Knock Sens Noise Channel Low Voltage
P0328 Knock Sens1 Circ Hi Bank1 or Single Sens
P0329 Knock Sens1 Circ Input Interm Bank1 or Single Sens
P0330 Knock Sens #2 Circ
P0331 Knock Sens2 Circ Range/Perf Bank2
P0332 Knock Sens2 Circ Low Bank2
P0333 Knock Sens2 Circ Hi Bank2
P0334 Knock Sens2 Circ Input Interm Bank2
P0335 Crank Pos Sens Circ
P0336 Crank Pos Sens Perf
P0337 Crank Pos Sens Circ Low
P0338 Crank Pos Sens Circ Hi
P0339 Crank Pos Sens Circ Interm
P0340 No Cam Signal At PCM
P0341 CMP Sens Signal
P0342 ESS Voltage Supply Low
P0343 ESS Voltage Supply Hi
P0344 Camshaft Pos Sens A Circ Interm Bank1 or Single Sens
P0345 Camshaft Pos Sens A Circ Bank2
P0346 Camshaft Pos Sens A Circ Range/Perf Bank2
P0347 Camshaft Pos Sens A Circ Low Bank2
P0348 Camshaft Pos Sens A Circ Hi Bank2
P0349 Camshaft Pos Sens A Circ Interm Bank2
P0350 Ignition Coil Draws Too Much Current
P0351 Ignition Coil # 1 Primary Circ
P0352 Ignition Coil # 2 Primary Circ
P0353 Ignition Coil # 3 Primary Circ
P0354 Ignition Coil # 4 Primary Circ
P0355 Ignition Coil # 5 Primary Circ
P0356 Ignition Coil # 6 Primary Circ
P0357 Ignition Coil # 7 Primary Circ
P0358 Ignition Coil # 8 Primary Circ
P0359 Ignition Coil I Primary/Sec Circ
P0360 Ignition Coil J Primary/Sec Circ
P0361 Ignition Coil K Primary/Sec Circ
P0362 Ignition Coil L Primary/Sec Circ
P0363 Misfire Detected-Fueling Disabled
P0365 Camshaft Pos Sens B Circ Bank1
P0366 Camshaft Pos Sens B Circ Range/Perf Bank1
P0367 Camshaft Pos Sens B Circ Low Bank1
P0368 Camshaft Pos Sens B Circ Hi Bank1
P0369 Camshaft Pos Sens B Circ Interm Bank1
P0370 Fuel Inj Pump Speed/Pos Sens Signal Lost
P0371 Timing Ref Hi Res Signal A Too Many Pulses
P0372 Timing Ref Hi Res Signal A Too Few Pulses
P0373 Timing Ref Hi Res Signal A Interm/Erratic Pulses
P0374 Timing Ref Hi Res Signal A No Pulse
P0375 Timing Ref Hi Res Signal B
P0376 Timing Ref Hi Res Signal B Too Many Pulses
P0377 Timing Ref Hi Res Signal B Too Few Pulses
P0378 Timing Ref Hi Res Signal B Interm/Erratic Pulses
P0379 Timing Ref Hi Res Signal B No Pulses
P0380 Glow Plug Circ Perf
P0380 Intake Air Heater Relay No. 1 Ctrl Circ or
P0381 Wait To Start Lamp Inoperative
P0382 Intake Air Heater Relay No. 2 Ctrl Circ
P0383 P0384 Reserved by document
P0385 Crank Pos Sens B Circ
P0386 Crank Pos Sens B Circ Range/Perf
P0387 CKP Sens Supply Voltage Too Low
P0388 CKP Sens Supply Voltage Too Hi
P0389 Crank Pos Sens B Circ Interm
P0390 Camshaft Pos Sens B Circ Bank2
P0391 Camshaft Pos Sens B Circ Range/Perf Bank2
P0392 Camshaft Pos Sens B Circ Low Bank2
P0393 Camshaft Pos Sens B Circ Hi Bank2
P0394 Camshaft Pos Sens B Circ Interm Bank2
Old 03-10-2009, 08:42 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
P0400 - P0499
P0400 Exhaust Gas Recirculation (EGR) Flow Malfunction
P0401 EGR Sys Failure
P0402 EGR Flow Excessive Detected
P0403 EGR Solenoid Circ
P0404 EGR Pos Sens Rationality
P0405 EGR Pos Sens Volts Too Low
P0406 EGR Pos Sens Volts Too Hi
P0407 Exhaust Gas Recirculation Sens B Circ Low
P0408 Exhaust Gas Recirculation Sens B Circ Hi
P0409 Exhaust Gas Recirculation Sens A Circ
P0410 AIR Sys
P0411 Sec Air Inj Sys Incorrect Flow Detected
P0412 Sec Air Solenoid Circ
P0413 Sec Air Inj Sys Switching Valve A Circ Open
P0414 Sec Air Inj Sys Switching Valve A Circ Shorted
P0415 Sec Air Inj Sys Switching Valve B Circ
P0416 Sec Air Inj Sys Switching Valve B Circ Open
P0417 Sec Air Inj Sys Switching Valve B Circ Shorted
P0418 Sec Air Inj Sys Ctrl A Circ
P0419 Sec Air Inj Sys Ctrl B Circ
P0420 1/1 Catalytic Conv Eff
P0421 Warm Up Catalyst Eff Below Threshold Bank1
P0422 Main Catalyst Eff Below Threshold Bank1
P0423 Heated Catalyst Eff Below Threshold Bank1
P0424 Heated Catalyst Temp Below Threshold Bank1
P0425 Catalyst Temp Sens Bank1
P0426 Catalyst Temp Sens Range/Perf Bank1
P0427 Catalyst Temp Sens Low Bank1
P0428 Catalyst Temp Sens Hi Bank1
P0429 Catalyst Heater Ctrl Circ Bank1
P0430 1/2 Catalytic Conv Eff
P0431 Warm Up Catalyst Eff Below Threshold Bank2
P0432 1/2 Catalytic Conv Eff
P0433 Heated Catalyst Eff Below Threshold Bank2
P0434 Heated Catalyst Temp Below Threshold Bank2
P0435 Catalyst Temp Sens Bank2
P0436 Catalyst Temp Sens Range/Perf Bank2
P0437 Catalyst Temp Sens Low Bank2
P0438 Catalyst Temp Sens Hi Bank2
P0439 Catalyst Heater Ctrl Circ Bank2
P0440 Evap Sys Perf
P0441 Evap Purge Flow Monitor
P0442 Evap Leak Monitor Medium Leak Detected
P0443 Evap Purge Solenoid Circ
P0444 Evap Emission Sys Purge Ctrl Valve Circ Open
P0445 Evap Emission Sys Purge Ctrl Valve Circ Shorted
P0446 Evap Emissions Vent Valve Perf
P0447 Evap Emission Sys Vent Ctrl Circ Open
P0448 Evap Emission Sys Vent Ctrl Circ Shorted
P0449 Evap Emission Sys Vent Valve/Solenoid Circ
P0450 Evap Emission Sys Press Sens/Switch
P0451 Evap Emission Sys Press Sens/Switch Range/Perf
P0452 Evap Emissions Press Sens Circ Low Volts
P0453 Evap Emissions Press Sens Circ Hi Volts
P0454 Evap Emission Sys Press Sens/Switch Interm
P0455 Evap Leak Monitor Large Leak Detected
P0456 Evap Leak Monitor Small (0.020) Leak Detected
P0457 EVAP Emission Sys Leak Detected (fuel cap loose/off)
P0458 EVAP Emission Sys Purge Ctrl Valve Circ Low
P0459 EVAP Emission Sys Purge Ctrl Valve Circ Hi
P0460 Fuel Level Unit No Change Over Miles
P0461 Fuel Level Unit No Changeover Time
P0462 Fuel Level Sending Unit Volts Too Low
P0463 Fuel Level Sending Unit Volts Too Hi
P0464 Fuel Level Sens A Circ Interm
P0465 EVAP Purge Flow Sens Circ
P0466 EVAP Purge Flow Sens Circ Range/Perf
P0467 EVAP Purge Flow Sens Circ Low
P0468 EVAP Purge Flow Sens Circ Hi
P0469 EVAP Purge Flow Sens Circ Interm
P0470 Exhaust Press Sens
P0471 Exhaust Press Sens Range/Perf
P0472 Exhaust Press Sens Low
P0473 Exhaust Press Sens Hi
P0474 Exhaust Press Sens Interm
P0475 EPR Solenoid Circ
P0476 Exhaust Press Ctrl Valve Range/Perf
P0477 Exhaust Press Ctrl Relay Low
P0478 Exhaust Press Ctrl Relay Hi
P0479 Exhaust Press Ctrl Valve Interm
P0480 Cooling Fan1 Ctrl Circ Open(Low speed fan)
P0481 Fan 2 Ctrl Circ
P0482 Fan 3 Ctrl Circ
P0483 Cooling Fan Speed
P0484 Fan Circ Over Current
P0485 Fan Power/Ground Circ
P0486 Exhaust Gas Recirculation Sens B Circ
P0487 Exhaust Gas Recirculation Throttle Pos Ctrl Circ
P0488 Exhaust Gas Recirculation Throttle Pos Ctrl Range/Perf
P0489 Exhaust Gas Recirculation Ctrl Circ Low
P0490 Exhaust Gas Recirculation Ctrl Circ Hi
P0491 Sec Air Inj Sys Insufficient Flow Bank1
P0492 Sec Air Inj Sys Insufficient Flow Bank2
P0493 Fan Overspeed
P0494 Fan Speed Low
P0495 Fan Speed Hi
P0496 EVAP Emission Sys Hi Purge Flow
P0497 EVAP Emission Sys Low Purge Flow
Old 03-10-2009, 08:43 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
P0500 - P0599
P0500 No Vehicle Speed Sens Signal
P0501 Vehicle Speed Sens Perf
P0502 Vehicle Speed Sens A Circ Low Input
P0503 Vehicle Speed Sens A Interm/Erratic/Hi
P0504 Brake Switch A/B Correlation
P0505 Idle Air Ctrl Motor Circs
P0506 Idle Ctrl Sys Low RPM
P0507 Idle Ctrl Sys Hi RPM
P0508 Undercurrent condition detected in linear idle air Ctrl motor feedback sense Circ
P0509 Over current condition detected in linear idle air Ctrl motor feedback sense Circ
P0510 Closed Throttle Pos Switch
P0511 Idle Air Ctrl Circ
P0512 Starter Request Circ
P0513 Incorrect Immobilizer Key
P0514 Battery Temp Sens Perf
P0515 Battery Temp Sens Circ
P0516 Battery Temp Sens Low
P0517 Battery Temp Sens Hi
P0518 Idle Air Ctrl Circ Interm
P0519 Idle Air Ctrl Sys Perf
P0520 Engine Oil Press Sens/Switch Circ
P0521 Oil Press Sens Perf
P0522 Oil Press Sens Low
P0523 Oil Press Sens Hi
P0524 Oil Press Too Low
P0525 Cruise Ctrl Servo Ctrl Circ Range/Perf
P0526 Fan Speed Sens Circ
P0527 Fan Speed Sens Circ Range/Perf
P0528 Fan Speed Sens Circ No Signal
P0529 Fan Speed Sens Circ Interm
P0530 A/C Refrigerant Press Sens A Circ
P0531 A/C Refrigerant Press Sens A Circ Range/Perf
P0532 A/C Press Sens Low
P0533 A/C Press Sens Hi
P0534 Air Conditioner Refrigerant Charge Loss
P0535 A/C Evaporator Temp Sens Circ
P0536 A/C Evaporator Temp Sens Circ Range/Perf
P0537 A/C Evaporator Temp Sens Circ Low
P0538 A/C Evaporator Temp Sens Circ Hi
P0539 A/C Evaporator Temp Sens Circ Interm
P0540 Intake Air Heater A Circ
P0541 Intake Air Relay 1 Low
P0542 Intake Air Relay 1 Hi
P0543 Intake Air Heater A Circ Open
P0544 Exhaust Gas Temp Sens Circ Bank1 Sens1
P0545 A/C Clutch Relay Circ
P0546 Exhaust Gas Temp Sens Circ Hi Bank1 Sens1
P0547 Exhaust Gas Temp Sens Circ Bank2 Sens1
P0548 Exhaust Gas Temp Sens Circ Low Bank2 Sens1
P0549 Exhaust Gas Temp Sens Circ Hi Bank2 Sens1
P0550 Power Steering Press Sens/Switch Circ
P0551 Power Steering Switch Failure
P0552 Power Steering Press Sens/Switch Circ Low Input
P0553 Power Steering Press Sens/Switch Circ Hi Input
P0554 Power Steering Press Sens/Switch Circ Interm
P0555 Brake Booster Press Sens Circ
P0556 Brake Booster Press Sens Circ Range/Perf
P0557 Brake Booster Press Sens Circ Low Input
P0558 Brake Booster Press Sens Circ Hi Input
P0559 Brake Booster Press Sens Circ Interm
P0560 Sys Voltage
P0561 Sys Voltage Unstable
P0562 Charging Sys Voltage Too Low
P0563 Charging Sys Voltage Too Hi
P0564 Cruise Ctrl Multi-Function Input A Circ
P0565 Cruise Ctrl On Signal
P0566 Cruise Ctrl Off Signal
P0567 Cruise Resume Circ
P0568 Cruise Set Circ
P0569 Cruise Ctrl Coast Signal
P0570 Cruise Ctrl Accelerate Signal
P0571 Cruise Brake Switch Circ
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 Hi
P0574 Cruise Ctrl Sys-Vehicle Speed Too Hi
P0575 Cruise Switch Failure (Shorted)
P0576 Cruise Ctrl Input Circ Low
P0577 Cruise Switch Failure (Open)
P0578 Cruise Ctrl Multi-Function Input A Circ Stuck
P0579 Cruise Ctrl Multi-Function Input A Circ Range/Perf
P0580 Speed Ctrl Multiplexed Switch 1 Low
P0581 Speed Ctrl Multiplexed Switch 1 Hi
P0582 Cruise Ctrl Vacuum Ctrl Circ/Open
P0583 Cruise Ctrl Vacuum Ctrl Circ Low
P0584 Cruise Ctrl Vacuum Ctrl Circ Hi
P0585 Cruise Ctrl Multi-Function Input A/B Correlation
P0586 Cruise Ctrl Vent Ctrl Circ/Open
P0587 Cruise Ctrl Vent Ctrl Circ Low
P0588 Cruise Ctrl Vent Ctrl Circ Hi
P0589 Cruise Ctrl Multi-Function Input B Circ
P0590 Cruise Ctrl Multi-Function Input B Circ Stuck
P0591 Cruise Ctrl Multi-Function Input B Circ Range/Perf
P0592 Cruise Ctrl Multi-Function Input B Circ Low
P0593 Cruise Ctrl Multi-Function Input B Circ Hi
P0594 Cruise Ctrl Servo Ctrl Circ/Open
P0595 Cruise Ctrl Servo Ctrl Circ Low
P0596 Cruise Ctrl Servo Ctrl Circ Hi
P0597 Thermostat Heater Ctrl Circ/Open
P0598 Thermostat Heater Ctrl Circ Low
P0599 Thermostat Heater Ctrl Circ Hi
Old 03-10-2009, 08:48 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
P0600 - P0699
P0600 PCM Failure SPI Comms
P0601 PCM Internal Ctrller Failure
P0602 ECM Fueling Calibration Error
P0603 VCM Memory Reset
P0604 RAM Check Failure
P0605 ROM Check Failure
P0606 ECM Failure
P0607 ECU Internal Perf
P0608 Ctrl Mod VSS Output A
P0609 Ctrl Mod VSS Output B
P0610 Ctrl Mod Vehicle Options Error
P0611 Fuel Injector Ctrl Mod Perf
P0612 Fuel Injector Ctrl Mod Relay Ctrl
P0613 TCM Processor
P0614 ECM / TCM Incompatible
P0615 Starter Relay Ctrl Circ
P0616 Starter Relay Circ Low
P0617 Starter Relay Circ Hi
P0618 Alternative Fuel Ctrl Mod KAM Error
P0619 Alternative Fuel Ctrl Mod RAM/ROM Error
P0620 Generator Ctrl Circ
P0621 Alternator L Terminal Circ
P0622 Alternator Field Not Switching Properly
P0623 Generator Lamp Ctrl Circ
P0624 Fuel Cap Lamp Ctrl Circ
P0625 Generator Field/F Terminal Circ Low
P0626 Generator Field/F Terminal Circ Hi
P0627 Fuel Pump A Ctrl Circ /Open
P0628 Fuel Pump Relay Circ Low (or)
P0628 Fuel Lift Pump Ctrl Circ Low
P0629 Fuel Pump Relay Circ Hi (or)
P0629 Fuel Lift Pump Ctrl Circ Hi
P0630 VIN Not Programmed in PCM
P0631 VIN Not Programmed or Incompatible-TCM
P0632 Odometer Not Programmed-ECM/PCM
P0633 SKIM Key Not Programmed in PCM
P0634 PCM/ECM/TCM Internal Temp Too Hi
P0635 Power Steering Ctrl Circ
P0636 Power Steering Ctrl Circ Low
P0637 Power Steering Ctrl Circ Hi
P0638 Throttle Actuator Ctrl Range/Perf Bank1
P0639 Throttle Actuator Ctrl Range/Perf Bank2
P0640 Intake Air Heater Ctrl Circ
P0641 Sens Ref Voltage A Circ/Open
P0642 Sens Ref Voltage 1 Circ Low
P0643 Sens Ref Voltage 1 Circ Hi
P0644 Driver Display Serial Comm Circ
P0645 A/C Clutch Relay Circ Perf
P0646 A/C Clutch Relay Circ Low
P0647 A/C Clutch Relay Circ Hi
P0648 Immobilizer Lamp Ctrl Circ
P0649 Speed Ctrl Lamp Ctrl Circ
P0650 Malfunction Indicator Lamp (MIL) Circ
P0651 Sens Ref Voltage B Circ/Open
P0652 Sens Ref Voltage 2 Circ Low
P0653 Sens Ref Voltage 2 Circ Hi
P0654 Engine Speed Output Circ
P0655 Engine Hot Lamp Output Ctrl Circ
P0656 Fuel Level Output Circ
P0657 Actuator Supply Voltage A Circ/Open
P0658 Actuator Supply Voltage A Circ Low
P0659 Actuator Supply Voltage A Circ Hi
P0660 Intake Manif Tuning Valve Ctrl Circ/Open Bank1
P0661 Intake Manif Tuning Valve Ctrl Circ Low Bank1
P0662 Intake Manif Tuning Valve Ctrl Circ Hi Bank1
P0663 Intake Manif Tuning Valve Ctrl Circ/Open Bank2
P0664 Intake Manif Tuning Valve Ctrl Circ Low Bank2
P0665 Intake Manif Tuning Valve Ctrl Circ Hi Bank2
P0666 PCM/ECM/TCM Internal Temp Sens Circ
P0667 PCM/ECM/TCM Internal Temp Sens Range/Perf
P0668 PCM/ECM/TCM Internal Temp Sens Circ Low
P0669 PCM/ECM/TCM Internal Temp Sens Circ Hi
P0670 Glow Plug Mod Ctrl Circ
P0671 Cylinder 1 Glow Plug Circ
P0672 Cylinder 2 Glow Plug Circ
P0673 Cylinder 3 Glow Plug Circ
P0674 Cylinder 4 Glow Plug Circ
P0675 Cylinder 5 Glow Plug Circ
P0676 Cylinder 6 Glow Plug Circ
P0677 Cylinder 7 Glow Plug Circ
P0678 Cylinder 8 Glow Plug Circ
P0679 Cylinder 9 Glow Plug Circ
P0680 Cylinder 10 Glow Plug Circ
P0681 Cylinder 11 Glow Plug Circ
P0682 Cylinder 12 Glow Plug Circ
P0683 Glow Plug Ctrl Mod to PCM Comm Circ
P0684 Glow Plug Ctrl Mod to PCM Comm Circ Range/Perf
P0685 ECM/PCM Power Relay Ctrl Circ /Open
P0686 ECM/PCM Power Relay Ctrl Circ Low
P0687 ECM/PCM Power Relay Ctrl Circ Hi
P0688 ECM/PCM Power Relay Sense Circ /Open
P0689 ECM/PCM Power Relay Sense Circ Low
P0690 ECM/PCM Power Relay Sense Circ Hi
P0691 Fan 1 Ctrl Circ Low
P0692 Fan 1 Ctrl Circ Hi
P0693 Fan 2 Ctrl Circ Low
P0694 Fan 2 Ctrl Circ Hi
P0695 Fan 3 Ctrl Circ Low
P0696 Fan 3 Ctrl Circ Hi
P0697 Sens Ref Voltage C Circ/Open
P0698 Sens Ref Voltage 3 Circ Low
P0699 Sens Ref Voltage 3 Circ Hi
Old 03-10-2009, 08:49 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
P0700 - P0799
P0700 EATX Ctrller DTC Present
P0701 Trans Ctrl Sys Range/Perf
P0702 Trans Ctrl Sys Electrical
P0703 Brake Switch Sense Circ
P0704 Clutch Switch Circ (M/T)
P0705 Trans Range Sens Circ Malfunction (PRNDL Input)
P0706 Trans Range Sens Circ Range/Perf
P0707 Trans Range Sens Circ Low
P0708 Trans Range Sens Circ Hi
P0709 Trans Range Sens Circ Interm
P0710 Trans Fluid Temp Sens A Circ
P0711 Trans Temp Sens, No Temp Rise After Start
P0712 Trans Temp Sens Voltage Too Low
P0713 Trans Temp Sens Voltage Too Hi
P0714 Trans Fluid Temp Sens A Circ Interm
P0715 Input/Turbine Speed Sens A Circ
P0716 Input/Turbine Speed Sens A Circ Range/Perf
P0717 Input/Turbine Speed Sens A Circ No Signal
P0718 Input/Turbine Speed Sens A Circ Interm
P0719 Brake Switch B Circ Low
P0720 Low Output SPEED Sens RPM, Above 15 MPH
P0721 Output Speed Sens Circ Range/Perf
P0722 Output Speed Sens Circ No Signal
P0723 Output Speed Sens Circ Interm
P0724 Brake Switch B Circ Hi
P0725 Engine Speed Input Circ
P0726 Engine Speed Input Circ Range/Perf
P0727 Engine Speed Input Circ No Signal
P0728 Engine Speed Input Circ Interm
P0729 Gear 6 Incorrect Ratio
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circ
P0738 TCM Engine Speed Output Circ Low
P0739 TCM Engine Speed Output Circ Hi
P0740 Torque Conv Clutch, No RPM Drop at Lockup
P0741 Torque Conv Clutch Circ Perf or Stuck Off
P0742 Torque Conv Clutch Circ Stuck On
P0743 Torque Conv Clutch Solenoid/Trans Relay Circs
P0744 Torque Conv Clutch Circ Interm
P0745 Press Ctrl Solenoid A
P0746 Press Ctrl Solenoid A Perf or Stuck Off
P0747 Press Ctrl Solenoid A Stuck On
P0748 Governor Press Sol Ctrl/Trans Relay Circs
P0749 Press Ctrl Solenoid A Interm
P0750 Shift Solenoid A
P0751 O/D Switch Pressed (Low) More Than 5 Minutes
P0752 Shift Solenoid A Stuck On
P0753 Trans 3-4 Shift Sol/Trans Relay Circs
P0754 Shift Solenoid A Interm
P0755 Shift Solenoid B
P0756 AW4 Shift Sol B (2-3) Functional Failure
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Interm
P0760 Shift Solenoid C
P0761 Shift Solenoid C Perf or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Interm
P0765 Shift Solenoid D
P0766 Shift Solenoid D Perf or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Interm
P0770 Shift Solenoid E
P0771 Shift Solenoid E Perf or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Interm
P0775 Press Ctrl Solenoid B
P0776 Press Ctrl Solenoid B Perf or Stuck off
P0777 Press Ctrl Solenoid B Stuck On
P0778 Press Ctrl Solenoid B Electrical
P0779 Press Ctrl Solenoid B Interm
P0780 Shift Error
P0781 1-2 Shift
P0782 2-3 Shift
P0783 3-4 Shift Sol, No RPM Drop at Lockup
P0784 4-5 Shift
P0785 Shift/Timing Solenoid
P0786 Shift/Timing Solenoid Range/Perf
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid Hi
P0789 Shift/Timing Solenoid Interm
P0790 Normal/Perf Switch Circ
P0791 Intermediate Shaft Speed Sens A Circ
P0792 Intermediate Shaft Speed Sens A Circ Range/Perf
P0793 Intermediate Shaft Speed Sens A Circ No Signal
P0794 Intermediate Shaft Speed Sens A Circ Interm
P0795 Press Ctrl Solenoid C
P0796 Press Ctrl Solenoid C Perf or Stuck off
P0797 Press Ctrl Solenoid C Stuck On
P0798 Press Ctrl Solenoid C Electrical
P0799 Press Ctrl Solenoid C Interm
Old 03-10-2009, 08:53 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
P0800 - P0899
P0800 Transfer Case Ctrl Sys (MIL Request)
P0801 Reverse Gear Lockout Circ Open or Short
P0802 Trans Ctrl Sys MIL Request Circ/Open
P0803 1-4 Upshift (Skip Shift) Solenoid Ctrl Circ
P0804 1-4 Upshift (Skip Shift) Lamp Ctrl Circ
P0805 Clutch Pos Sens Circ
P0806 Clutch Pos Sens Circ Range/Perf
P0807 Clutch Pos Sens Circ Low
P0808 Clutch Pos Sens Circ Hi
P0809 Clutch Pos Sens Circ Interm
P0810 Clutch Pos Ctrl Error
P0811 Excessive Clutch Slippage
P0812 Reverse Input Circ
P0813 Reverse Output Circ
P0814 Trans Range Display Circ
P0815 Upshift Switch Circ
P0816 Downshift Switch Circ
P0817 Starter Disable Circ
P0818 Driveline Disconnect Switch Input Circ
P0819 Up and Down Shift Switch to Trans Range Correlation
P0820 Gear Lever X-Y Pos Sens Circ
P0821 Gear Lever X Pos Circ
P0822 Gear Lever Y Pos Circ
P0823 Gear Lever X Pos Circ Interm
P0824 Gear Lever Y Pos Circ Interm
P0825 Gear Lever Push-Pull Switch (Shift Anticipate)
P0826 Up and Down Shift Switch Circ
P0827 Up and Down Shift Switch Circ Low
P0828 Up and Down Shift Switch Circ Hi
P0829 5-6 Shift
P0830 Clutch Depressed Switch Circ
P0831 Clutch Pedal Switch A Circ Low
P0832 Clutch Pedal Switch A Circ Hi
P0833 Clutch Released Switch Circ
P0834 Clutch Pedal Switch B Circ Low
P0835 Clutch Pedal Switch B Circ Hi
P0836 Four Wheel Drive (4WD) Switch Circ
P0837 4WD Switch Perf
P0838 4WD Switch Circ Low
P0839 4WD Switch Circ Hi
P0840 Trans Fluid Press Sens/Switch A Circ
P0841 Trans Fluid Press Sens/Switch A Circ Range/Perf
P0842 Trans Fluid Press Sens/Switch A Circ Low
P0843 Trans Fluid Press Sens/Switch A Circ Hi
P0844 Trans Fluid Press Sens/Switch A Circ Interm
P0845 Trans Fluid Press Sens/Switch B Circ
P0846 Trans Fluid Press Sens/Switch B Circ Range/Perf
P0847 Trans Fluid Press Sens/Switch B Circ Low
P0848 Trans Fluid Press Sens/Switch B Circ Hi
P0849 Trans Fluid Press Sens/Switch B Circ Interm
P0850 Park/Neutral Switch Input Circ
P0851 Park/Neutral Switch Input Circ Low
P0852 Park/Neutral Switch Input Circ Hi
P0853 Drive Switch Input Circ
P0854 Drive Switch Input Circ Low
P0855 Drive Switch Input Circ Hi
P0856 Traction Ctrl Input Signal
P0857 Traction Ctrl Input Signal Range/Perf
P0858 Traction Ctrl Input Signal Low
P0859 Traction Ctrl Input Signal Hi
P0860 Gear Shift Mod Comm Circ
P0861 Gear Shift Mod Comm Circ Low
P0862 Gear Shift Mod Comm Circ Hi
P0863 TCM Comm Circ
P0864 TCM Comm Circ Range/Perf
P0865 TCM Comm Circ Low
P0866 TCM Comm Circ Hi
P0867 Trans Fluid Press
P0868 Trans Fluid Press Low
P0869 Trans Fluid Press Hi
P0870 Trans Fluid Press Sens/Switch C Circ
P0871 Trans Fluid Press Sens/Switch C Circ Range/Perf
P0872 Trans Fluid Press Sens/Switch C Circ Low
P0873 Trans Fluid Press Sens/Switch C Circ Hi
P0874 Trans Fluid Press Sens/Switch C Circ Interm
P0875 Trans Fluid Press Sens/Switch D Circ
P0876 Trans Fluid Press Sens/Switch D Circ Range/Perf
P0877 Trans Fluid Press Sens/Switch D Circ Low
P0878 Trans Fluid Press Sens/Switch D Circ Hi
P0879 Trans Fluid Press Sens/Switch D Circ Interm
P0880 TCM Power Input Signal
P0881 TCM Power Input Signal Range/Perf
P0882 TCM Power Input Signal Low
P0883 TCM Power Input Signal Hi
P0884 TCM Power Input Signal Interm
P0885 TCM Power Relay Ctrl Circ/Open
P0886 TCM Power Relay Ctrl Circ Low
P0887 TCM Power Relay Ctrl Circ Hi
P0888 TCM Power Relay Sense Circ
P0889 TCM Power Relay Sense Circ Range/Perf
P0890 TCM Power Relay Sense Circ Low
P0891 TCM Power Relay Sense Circ Hi
P0892 TCM Power Relay Sense Circ Interm
P0893 Multiple Gears Engaged
P0894 Trans Component Slipping
P0895 Shift Time Too Short
P0896 Shift Time Too Long
P0897 Trans Fluid Deteriorated
P0898 Trans Ctrl Sys MIL Request Circ Low
Quick Reply: Diagnostic Trouble Code List
