Any interesting engine swaps in a 2nd gen?
Old 04-22-2013, 12:16 PM
Jigabop's Avatar
Jigabop
Jigabop is offline
^^^ Just make sure you put POWERED by CHEVY on it. If we are going stupid here why not a Man Dsl V8-1200hp out of the box.
http://www.man-engines.com/en/marine...t_engines.html
well the OP mentioned chevy motors earlier, complained that 350hp was not enough... said diesel parts cost too much, and complained that big blocks don't fit very well...
so I posted a turn key pump gas motor with more than enough power, and the block is the same size as a 360...
and being a chevy, parts are cheap and aftermarket support is plentiful.
speakin of....I want a motor like that for my S10. put a built T56 behind it and either a narrowed GM 12 bolt, or a narrowed ford 9" rear end behind it...
suppose I could get away with the posi 10 bolt it has now till it blows up but I don't think I will get enough traction to hurt the rear end honestly
  #22
Old 04-22-2013, 12:29 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
Man I am just one of those guys, keep it brand specific thats just me though. I can't argue your info on the Chevy stuff its true.
Edit: There is more than enough room for a BBM in that engine bay.
The following users liked this post:
Benjamin S Goodliffe (01-31-2021)
  #23
Old 04-22-2013, 12:56 PM
Jigabop's Avatar
Jigabop
Jigabop is offline
yep, chevy motors are the cheapest to build, mopar is about the middle of the road in cost to build, and ford is the most expensive to build (out of the big 3)
My S10 build would stay brand specific
Sad thing is it would likely get better fuel economy with the built v8 than it does with the 4 banger it has now...
thing is not geared right at all... 4.10 rear end with a 4-spd manual (no overdrive)
what's worse: because of that crappy gearing...my diesel has less than a 1mpg difference in fuel economy to the S10...S10 gets 16mpg...
  #24
Old 04-22-2013, 01:07 PM
merc225hp's Avatar
merc225hp
I can't yap on Ford prices as I just don't see many of them, I don't like the rash they give me. You will get better mpg with the sbc in the little s-10 my guess is 25+ on the hwy.
  #25
Old 04-22-2013, 01:23 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
I have seen properly tuned TPI SBC in S trucks/blazers pushing 29 MPG on the freeway. LOTS of low end grunt on those too...... it's a great combination.
  #26
Old 04-22-2013, 02:20 PM
merc225hp's Avatar
merc225hp
I guess if I was to cross-breed gas for gas it would be nothing shy of a BBC 454 at min. I have had a couple of big old 70's Chevy trucks, 38+ tires, big lifts, bad gears 3.73, 4 spd bow-low stick trannys, smog head carbed 454's and they got the same mpg (12-14) as my little Dodge, at times better than these mpi motors get.
  #27
Old 04-22-2013, 02:45 PM
HeyYou is offline
If I could find a mid-2000's camaro for sale cheap, I would consider buying it, and doing an LS swap into my truck......
  #28
Old 04-22-2013, 02:59 PM
98Ramboy's Avatar
98Ramboy
98Ramboy is offline
My dad just sold his '98 Z28 with only 35k miles on it! It was insane!!
  #29
Old 04-22-2013, 03:00 PM
merc225hp's Avatar
merc225hp
LS6 or ???
  #30
Old 04-22-2013, 03:01 PM
98Ramboy's Avatar
98Ramboy
98Ramboy is offline
I don't know much about Chevy's, but I know that the 454 SS Chevy trucks are pretty mean, I've got a rivalry with this kid who has one at school. One day, I might be able to take him.
Quick Reply: Any interesting engine swaps in a 2nd gen?
