snowboundrmk's 360 build
Old 04-14-2014, 02:59 PM
snowboundrmk's Avatar
snowboundrmk
snowboundrmk is offline
Go buy a new key, I have tried that welding trick before, the weld will eventually crack and break off the key. Then where will that welded piece end up?
Did your weld come apart? It's a tight interference fit so even if it did break I don't think it could go anywhere. Plus the cam bolt is covering it. I couldn't find a replacement key anywhere and the stock key didn't have any signs of wear so even if I did source a new key I think I would have the same problem.
  #152
Old 04-21-2014, 12:30 AM
snowboundrmk
I got some more stuff in the mail and mounted the heads and put the lifters in. Can't do anymore on the engine until I order a couple more parts, but I can work on the exhaust and get the cai mounted I got from tincan with the gasket that came. My spark plugs I got say small engine on them but they are the right part number. Will they work?
  #153
Old 05-03-2014, 10:07 PM
snowboundrmk
Put in my pushrods and put on the rockers. Also put in the front cover seal and new cam key and I got the last of my parts in the mail except my reflex header gaskets which are m.i.a.
  #154
Old 05-04-2014, 07:43 PM
Blue Mopar01's Avatar
Blue Mopar01
Blue Mopar01 is offline
Headers look pretty nice! Let me know if your collector flanges leak or not, I still haven't gotten mine to seal up
  #155
Old 05-04-2014, 10:49 PM
snowboundrmk
Put the timing cover, water pump, and balancer on. Temporarily put on valve covers and oil pan for painting.
  #156
Old 05-05-2014, 12:10 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
looks dang spanky my friend!! Getting real close!
  #157
Old 05-07-2014, 10:14 PM
snowboundrmk
Started masking it off for some hemi orange.
  #158
Old 05-07-2014, 11:33 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,206 Likes on 2,958 Posts
But it looks so CLEANNNNNNN.
  #159
Old 05-12-2014, 08:37 PM
snowboundrmk
Made some progress on the exhaust. It's taking longer than I thought it would.
  #160
Old 05-12-2014, 10:14 PM
tincan57's Avatar
tincan57
tincan57 is offline
Nice fit up...........Hope we get to hear it when complete. K.
Quick Reply: snowboundrmk's 360 build
