I replaceed my fuel pump last weekend and since then I have been haveing trouble starting my truck. It is not holding fuel pressure in the fuel line. What could be the cause of this? Could someone PLEASE HELP?
My 1998 Ram 1500 4x4 does the same thing with the air blowing out of defrost vents at high speeds??? No one answered your question, any answers? I would like to know myself?
intake plenum gasket is blown under your intake their is a steel plate and it expands and contracts at different temperature then the alluminum intake and it blows the gasket factory flaw go to hughes engines they sell an aluminum plate fix for that problem
Since it has been over a year.... I would like to think he has figured it out.
Not to beat a dead horse, but I don't think the steel plate/Al. manifold is the problem. It appears to me the problem is caused by the plenum pan bolts being a tad bit too long. That, and maybe the bolt spacing.
Unless you have a California version
your 1997 should NOT have an EGR valve,
which on 1992-1995 5.2/5.9 V8s
was located at the very back of the intake manifold.
How about on a 96? I've replace the tps on mine and it's still stalling. I've cleaned the port for it also. Those wonderful people at our local auto zone told me I do have an egr valve but I can't find it.
