Old 08-06-2015, 07:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
Transmission Diagnosis Charts
Old 02-01-2013, 12:10 AM
hotdakota's Avatar
hotdakota
hotdakota is offline
Originally Posted by aim4squirrels
this needs to be stickied to the top and the link smacked down as the first response to every tranny question that gets posted.
Hey rite on .. ive had 3 dodges tranny trouble with all this one is fourth dont know
im female and love them anyways just Bought it two trips to town and no tranny aftrr it warms for couple minutes gotta tear down next cple days figure it out..
Thanks lot for your help and anyone else...!
Old 02-01-2013, 07:17 AM
White5.9's Avatar
White5.9
White5.9 is offline
great find. I believe this may have solved my questions. Mew gov/valve body!
Old 02-02-2013, 10:59 PM
hotdakota's Avatar
hotdakota
Default runnin....! hooray...!
Hey thanks ...
Drained and cleaned up pan changed filter. Put the Atf type f and some that Dextron...like honey. Drives fine ..incredible.
now on to INstrumentation . the panel was disconnected when i got it . has power and lights no gauges.. crusie control fine.....hmmmm some said stero installtion went wrong.I hooked up perfect match its all good too...
anyways thanks again for your help im rolling on to salvage yard now for a windsheild too.
Old 02-02-2013, 11:39 PM
gdstock's Avatar
gdstock
gdstock is offline
Originally Posted by hotdakota
Hey thanks ...
ATF Type F is made for Ford Transmissions. You Need ATF+4. They are not the same, and definitely different from Dexron. Your firction coefficient for the fluids are different. You really need to drain that out and refill with the correct fluid.
Old 11-22-2017, 12:58 AM
Raygarza 07031973's Avatar
Raygarza 07031973
Raygarza 07031973 is offline
New Member
Hi I got a2007 Dodge Durango try to find out why it slowly. Started not shifting right .I have to shift from 2-drive after that it won't down shift
Old 11-22-2017, 09:52 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
You wanna be in the Durango section.
Old 01-17-2023, 03:43 PM
Tw1ZZLER's Avatar
Tw1ZZLER
Tw1ZZLER is offline
wrong thread
Quick Reply: Transmission Diagnosis Charts
